the 280 hks cams are in
it sounds so sick with the hks eids works like a champ. no stalling what so ever hks did these right. i give it a few pulls its running real rich right now im going to get it flashed in a few days to see what numbers i can get with stock turbo.
i hit the gas a few times and it just screams at u im happy ill be even more happy once i get the right a/f setting and timeing.
headers
o2 houseing
down pipe
test pipe
greddy ti catback
ams frount mount
injen intake
lower i/c pipe
ralliart wires
wepon r ingtion / grounding kit
hks ssqs bov
hks eids - (this is what makes the car run when i let off the gas it holds idle at 1500 then drops this thing is money)
fuel pump
280 cams hks
and a few other things that i just cant remeber right now
once i get the reflash and dyno it in a few weeks or 2 im getting a wide band and aem stand along. i cant be overnighting my ecu everytime i get something new you know.
i should lay down some good numbers wish me luck guys
o2 houseing
down pipe
test pipe
greddy ti catback
ams frount mount
injen intake
lower i/c pipe
ralliart wires
hks ssqs bov
fuel pump
280 cams hks
From what I've seen, 280s seem to slow response on the stock turbo. Some guys have apparently gone back to their original 264 or 272 cams after trying the 280s. What do the guys with 280s say?
I like the 280s, they give great top end response, depending on your cam gear settings you can also bring the powerband lower in the RPM range but you lose the top end pull. I prefer the high rpm power myself.
wow 280 cams huh! I wouldnt mind trying that. can you guys tell me pros and cons vrs my setup?
Mods.
05 evo MR.
atp gt3037s turbokit: o2 housing and tial 38mm wastegate.
stock block
stock head
stock intercooler
stock intake manifold
stock exhaust manifold
264intake cams
272 exhaust cams
skunk2 cam gears.
rc 750 injectors
walbro fuel pump
greddy types s bov
apexi turbo timer
apexi fuel management(forgot model number)
greddy profec b-spec2
buschur 3inch dump back(catless)
exedy twin plate clutch(stage 4)
in california on 91 octane at 21psi I put on a mustang dyno 373hp. which on dynojet is about 450. My guy at extreme imports said when he will flash my ecu on 26 psi c16 octane I will get 450hp mustang dyno which on dynojet is 550hp. what do you guys recommend next? I think I should start at my driveline(rear diff).....
I start boosting at 3400 rpm by the way.
Mods.
05 evo MR.
stock block
stock head
stock intercooler
264intake cams
272 exhaust cams
skunk2 cam gears.
rc 750 injectors
walbro fuel pump
greddy types s bov
apexi turbo timer
I just love the sound of healthy cams..
i have 280's with the 05 stocker and i love them. the higher the RPM the more the car pulls....i just can't wait to reinstall my 50 trim.
i am using them with the AEM with no cam gears and the idle is close to stock...never stalled or dipped.
i had 272's on my last car and if i could do it all over again...i would go with the 280's again....
Maybe it is just me, but is the theory of all the Japanese tuners to run low duration and high lift cams on a turbo car? Example the Jun's and the Tomei Pro cams. Turn large quantities of air on the turbo at once for a short period of time= spool and stability. Just my two cents
HKS cams are designed specifically to give you the most lift possible with safe durations that don't require valvespring upgrades or work to the pistons. So they use more duration and slightly less lift.
On our heads, the additional lift doesn't help quite as much without that duration, but any little bit helps.
