what kind of damage do I look for at 26 psi?
Old Aug 6, 2005 | 10:04 AM
bluebanana23's Avatar
I got my stock manifold and my RNR O2 housing coated and installed. My brother and friend took the car out without my permission so now my boost controller reads 26.3 psi as peak pressure and keep in mind I have the stock intercooler in Texas heat. What kind of damage am I looking at. Everything is stock except exhaust, intake, and base dynoflash. This was on 93 octane btw.
Old Aug 6, 2005 | 10:07 AM
EvoDan2004's Avatar
yea whiplash. it can do some damege.
Old Aug 6, 2005 | 10:43 AM
WrX Kila's Avatar
None. Make sure you have Headstuds and Good gas. On a stock turbo I dont think it will hold it anyway. Its going to fall off to 21psi anyway.
Old Aug 6, 2005 | 11:11 AM
QAT-R's Avatar
Btw, stock turbo has been known to spike as high as 31 psi....but yeah it should fall of pretty quick. The question is how long was the car @ 26 psi? and realistically their is no real way to determine if any damage was caused. I wouldn't worry about it but, take this chance to chew your bro out
Old Aug 6, 2005 | 11:48 AM
Widebandphillip's Avatar
doubt anything bad happend. It would have been actually best if you didn't have headstuds. I'd rather lift the head then blow a piston out. The stock ecu would have pulled massive timing.
Old Aug 6, 2005 | 11:54 AM
Gruppe-S's Avatar
I wouldn't worry about it unless it knocked really bad. 4G63 block can take some major boost...just make sure you are always running good gas.
Thanks,
Tom
bnr34rb26dett
Feb 3, 2011 05:35 AM
c0r3y.aF
Sep 30, 2009 06:25 AM
bigric09
Nov 29, 2006 11:56 AM
fuzzychi
10
Mar 11, 2005 01:18 PM
Dale_K
Aug 15, 2003 06:02 PM
