Problem starting car after header install
Old Aug 9, 2005 | 07:27 AM
joeymia's Avatar
Ever since I installed Megan Racing Headers my car has had problems starting while hot. If I were to drive somewhere and try to start the car while its hot it will give me problems. Sometimes it will just go *click* like if the battery was dead other times it will just crank for a few seconds as if the car wasn't getting any gas. The car has always started up the tho... I just turn the ignition off and try again and it starts. I have not been stranded yet. Has anyone had any problems like this? I am thinking the heat from the headers might affect something but I am kind of stumped.
Old Aug 9, 2005 | 07:32 AM
evo_il8's Avatar
try resetting the ecu
Old Aug 9, 2005 | 01:43 PM
joeymia's Avatar
I'll try that tonight... Anyone else have any suggestions?
Old Aug 9, 2005 | 03:02 PM
Evil_1's Avatar
Make sure you have good connections at the battery terminals. I use to have that problem on older cars and it's usually a faulty starter. Good luck.
Old Aug 9, 2005 | 04:26 PM
yokomo's Avatar
don't be too hard on yourself. YOu could be correct. That heat is unbearable. I too put on a header (SSAutoChrome). Extreme heat until I wrapped the header, but no problems like unable to start.
Like the other guy said, check your starter and your battery connections.
Good luck
Old Aug 9, 2005 | 04:58 PM
timzcat's Avatar
The battery cable at the starter has been known to come loose.
Old Aug 9, 2005 | 05:01 PM
Curt@MrLed's Avatar
Former Vendor
cable on the starter, or the switch on the clutch pedal is going bad.. or you neeed a new battery..
Old Aug 9, 2005 | 05:18 PM
mksevo's Avatar
the header has no direct effect on the car starting . i would start else where. starter, batter , 02 sensor, some other part that was hit or taken off during the install.
simple fix. replace your stock header and try again.
Old Aug 11, 2005 | 07:12 PM
joeymia's Avatar
Well my car did it again tonight. All it would do is just go *click* loudly followed by some really faint clicks till i turned the ignition off. Luckily I was with my girlfriend so I told her the crank the motor to see if i could spot something. I noticed that when the car was started something was glowing red from under the turbo. I could not tell exactly from well but i could see the redish glow. Could it be that the starter cables have melted togther and are shorting out? Here is a picture of the area where I saw the redish glow. The area is circled in blue.
Old Aug 11, 2005 | 07:20 PM
timzcat's Avatar
Starter wires. Probably loose like I said.
Old Aug 11, 2005 | 07:33 PM
joeymia's Avatar
Really hope its just that thanks Easy fix but I am going to wait till the weekend since I want to get some sleep tonight. If I can't start it tomorrow I'll just push start it so I can get to work. Hopefully no one sees me push starting it at work... I already catch enough flack about owning a hehe.
Old Aug 11, 2005 | 07:41 PM
mksevo's Avatar
sounds like a short for sure. be careful and disconect the battery
240Z TwinTurbo
196
Nov 3, 2015 12:29 PM
dylan_EVO_VIII
Nov 27, 2011 03:13 PM
voidhawk
Northwest Region
60
Apr 4, 2008 12:42 PM
rayabedi
Lancer Engine Tech
228
Jul 7, 2004 02:32 PM
digdat
Lancer Engine Tech
Apr 1, 2004 12:43 PM
