Alchohol injection and GT35R
Hey guys,
This weekend at the shootout I was able to run some traps in the 120 mph range. With my fat @ss in the car it weighs 3400 lbs. (on a scale, not a guesstimate) Using the on line hp calculators that puts me in the 460 wheel HP level (dynojet equivelent numbers) at 25 psi on 93 octane with the alcohol injection
That would be around 390 wheel HP on a dyno dynamics dynometer, right around 550 at the crank.
Just had to say how happy I am with the setup
Keith
That would be around 390 wheel HP on a dyno dynamics dynometer, right around 550 at the crank.Just had to say how happy I am with the setup
Keith
Good number. I just ran a 119.6 with my 35r, but had considerable problems getting off the line. Bogged BIG time. What rpm are you launching at and what engine management are you using?
Keith
Originally Posted by Rez90
cool man...it seems like everyone is going with alcohol...
how is the spool on your turbo and what 35r are you running.
Keith
Originally Posted by Fourdoor
Buschurs older GT35R kit with the .63 A/R exhaust housing. Check out the other thread about GT35R spool.
Keith
Keith
Well done Keith!
I'm headed out Wednesday to get some methanol/35R times. I haven't been out yet with the new setup.
OT Question: Have you fouled a plug yet with the alky/methanol injection?
Originally Posted by TwStDeVo
was this on a conservative tune? i remember seing evodave's thread where he got a little over 550whp on pump and alky. i am in a tough situation, i live in an area that is 6000ft above sea level. i want the 35r but worried about spool up. i have been following the other thread closely. a local person bought a 3076 and says he gets full boost around 4500, so i figure the 35r would be around 5000. would it still be worth buying the 35r or should i just stick with something like the buschur 20g? i will be using the utec for tuning.
Keith
PS: Always ask what people define as "full boost" and what gear they are doing the pull in. Someone running 30 psi will hit full boost later than someone running 25 psi on the same turbo, and someone doing pulls in 4th gear will reach full boost sooner than someone doing pulls in 3rd gear.
Originally Posted by EVOlunchbox
Well done Keith!
I have not had a problem with fouling plugs, but I have the HKS DLI 2 also. The boost does flutter a bit when the alcohol first starts spraying (between 20 and 23 psi). Not sure if ignition is being effected or if I nead to lean it out a bit in that area. Data logs look good, so I may gap the plugs down just a bit.
Keith
Originally Posted by evo_il8
nice setup im wonderin how much r u spinnin off the line and what tires u runnin??
Keith
