Cusco twin metallic clutch....ADVICE NEEDED
Old Aug 15, 2005 | 06:23 PM
gsujeff55's Avatar
Anyone running the cusco twin metallic clutch? If so, how you like it? Come with everyhting you need? Any problems? Hows the shifting and shift times?
I am in a bind and am going to have to act fast....any help would be appreciated!
Thanks, Jeff
Old Aug 15, 2005 | 07:16 PM
wthoevo8's Avatar
I've mine for 7k miles, no problem so far shift good, clutch pedal a little on the heavy side, you'll need throw out bearing.
Thanks, Jeff
Old Aug 15, 2005 | 07:22 PM
gsujeff55's Avatar
If i jsut installed an ACT about 1000 miles ago...can i re-use that throw out bearing?
Old Aug 15, 2005 | 07:53 PM
ct9a gsr's Avatar
I had the Cusco twin-disk clutch... it's cerametallic with carbon friction surfaces. Shifting is very smooth with this clutch... extremely smooth. It can be slipped quite a bit as well... a very good clutch.
However, I managed to destroy one in about 3-4 months... but that was due to my broken crankshaft, not driver error. I'd recommend this clutch if I had the money for another one.
Old Aug 15, 2005 | 07:56 PM
gsujeff55's Avatar
you broke a crankshaft? damn.
Old Aug 16, 2005 | 05:05 AM
gsujeff55's Avatar
mornin' bump
Old Aug 16, 2005 | 05:43 AM
SuperHatch's Avatar
I have one, has been holding up well for 10k hard hard miles.... I'm doing a 4.11 upgrade and 4th gear syncro repair this winter. When I do I'm sending the clutch back to exedy to have it remanufactured or just buying new disks depending on the wear I see. It seems to be grabbing a little higher than it used to (disk wear). I love the clutch and would buy it again if I had to, smooth engagement and good driveability.
- Steve
P.S. - For the 40 bucks a TOB costs, just do it. I know yours only has 1000 miles on it, but if it gets damaged while removing the old clutch, etc. it's not worth the headache of having to go in there again. Just my opinion...
Old Aug 16, 2005 | 05:49 AM
gsujeff55's Avatar
what exactly is the difference in the cusco and the exedy? nothing? or just different discs?
Old Aug 16, 2005 | 05:59 AM
SuperHatch's Avatar
Yes, different disks, if you talk to Matt Gold (an exedy rep that frequents here) he can give you the part number for the Exedy clutch configuration that is equivalent to the Cusco. Although, the PP will be purple, if that matter to you
- Steve
Old Aug 16, 2005 | 06:04 AM
gsujeff55's Avatar
you have a number for him?
Old Aug 16, 2005 | 07:46 AM
SuperHatch's Avatar
His screen name is MattGold if you want to send him a PM.
I will PM you his number as well...
- Steve
