Who using the Forge BOV Type RS Valve Kit
Are you having any problems with it? Any CEL or Stalling? Considering ordering over the GFB BOV and want to makes sure I'm getting the best bang for my buck. Thanks!!!
I have and I switched from a HKS SSQV. No problems easy install, super easy adjustment. Are you planning on running VTA? That is really the only time you should worry about stalling of idle issues.
Have you ever spoken with a rep from GFB? Ever seen one here on the forums? Support is worth alot. Apparently the Forge works fine in VTA, but it just doesn't make any sense to run it VTA with out stand alone engine management and a speed density set-up.
I have the complete kit for that exact reason. I plan on using EMS someday soon, but in the meantime I run the forge in recirc. If you do do VTA your car will run rich which means worse gas milage. Gas is too high for that.
