best investment a downpipe or an intake???
Old Sep 3, 2005 | 02:42 PM
tequila083's Avatar
i want more power i need to decide between an 2.5 HKS downpipe or an HKS RS intake. Which one should i install first?
Old Sep 3, 2005 | 02:45 PM
krafty's Avatar
Intake will require a tune..So I would say downpipe.
Old Sep 3, 2005 | 02:46 PM
Warrtalon's Avatar
I would say neither of those would be useful. You won't get any gain from a DP with the stock cat still in the middle. If you get a DP that is a one-piece design that includes the test pipe, then definitely get that. Otherwise, skip the DP. Also, don't get a 2.5" DP ever...only go 3".
The HKS RS intake will not give you any noticeable gain over the K&N, plus it will require a tune to work properly, so that's definitely not worth the money.
If you want to spend $200-250, then purchase a flash and enjoy the 20+ whp gain...
Old Sep 3, 2005 | 02:47 PM
evo_il8's Avatar
downpipe
Old Sep 3, 2005 | 02:48 PM
tequila083's Avatar
i am going to dynoflash my ecu does the downpipe have better results or the intake help more?
Old Sep 3, 2005 | 02:55 PM
YellowEvo03's Avatar
The intake won't help that much b/c it will require a tune. The downpipe won't work b/c stock catalytic converter is the major bottleneck of the exhaust system. If you get a tune, the intake will get you more power.
Old Sep 3, 2005 | 02:59 PM
Compjoc's Avatar
Downpipe
Old Sep 3, 2005 | 03:02 PM
Warrtalon's Avatar
I already answered that. You will get no gain from either, unless you consider 2whp for $250 to be a "better result."
Why do you want to purchase such an expensive intake if you already have a K&N filter? You're already getting 3-4whp from that filter and are having NO negative results in terms of hot engine air or turbulent MAF readings. The DP needs to be a 3" and needs to be combined with a cat replacement (test pipe or HFC).
Old Sep 3, 2005 | 03:04 PM
evoviiiny's Avatar
If the ecu is flashed, Al said the intake gains 11whp i think. If the downpipe is a catdelete i would go w/ that instead of an intake.
Old Sep 3, 2005 | 03:47 PM
tequila083's Avatar
i know that without tune the intake make a lean condition, but what are the results with the flash? do i keep my k&n or should i change before the flash for better results? I read a dynoflash threads and they said that Al can program the ecu for better results with an intake.
Old Sep 3, 2005 | 03:52 PM
pyrovice's Avatar
Wrong, the gains from the intake are on evos that already have TBE
Old Sep 3, 2005 | 04:02 PM
Z1 Performance's Avatar
the downpipe does not need to be 3 inches at all.....in fact with a stock turbo (non 10.5 hotside), it will matter very little if you go 2.5, 2.75 or 3 inch..get what fits your budget.
The downpipes that eliminate the stock cat are excellent pieces, but not everyone wants the noise. DC Sports and RSR are the 2 most popular. If you get a downpipe that does not integrate a test pipe, then you would be very well served to either mate it to a test pipe or mate it to a high flow cat.
