Boost decrease
Old Sep 7, 2005 | 08:51 PM
Boricua21's Avatar
Thumbs down Boost decrease Hellllp!!!
I instaled the Helix IC pipes and my boost when down from19psi to 12 psi I just did leak test but I couldn't find the darn leak if I had one don't know what to to and im realy tired of trouble shooting thi Fu***ng thing any sugestion please because Im about to turned thius **** to Gruppes.
Old Sep 7, 2005 | 08:58 PM
bolsen's Avatar
lol I'd definetly return them... sounds like you got the defective model
Old Sep 7, 2005 | 09:05 PM
Boricua21's Avatar
Originally Posted by bolsen
Sounds like you have them installed backwards...
What !! Dude I dont think so
Old Sep 7, 2005 | 09:08 PM
bolsen's Avatar
I was just kidding... sounded like you needed a little comic relief.
Just go back and do your leak tests! Patience is your friend
Old Sep 7, 2005 | 09:10 PM
Boricua21's Avatar
How come, could they be crack but the thing is I didn't have any leaks from them
Old Sep 7, 2005 | 09:14 PM
bolsen's Avatar
how are you testing for leaks?
Old Sep 7, 2005 | 09:32 PM
Boricua21's Avatar
Presurising the pipes with air connected to the turbo there is a few examples in this site I just follow them
Old Sep 8, 2005 | 05:46 PM
Boricua21's Avatar
I just conducted another leak test and I found tha my BOV was leaking a lot so I cahnged for the stock one and still hiting 12 psi the only thing I heard is from the troddle but sprayed a lot of soapy water and no bubbles could someone help.
Old Sep 8, 2005 | 05:48 PM
evo0486t's Avatar
do u have a boost controller??
Old Sep 8, 2005 | 05:49 PM
Boricua21's Avatar
No man but I ordered one a friend told me that that's the solution but if I cant find the leak if I have one wont that can mess my turbo
Old Sep 8, 2005 | 05:59 PM
Nad1370's Avatar
Why don't you try putting your stock pipes/hoses back and test it.
Process of elimination.
Old Sep 8, 2005 | 06:00 PM
Boricua21's Avatar
yea thats my next step
Old Sep 9, 2005 | 01:48 AM
aps's Avatar
aps
Did you feel turbo lag after installed the pipe's?
Old Sep 9, 2005 | 12:10 PM
Boricua21's Avatar
Yes I did but the thing is that everybody keeps teling me thats the pressure drop is normal, but what is normal cus my evo his engine is stock so what should be consider a perssure drop if you car is stock cus, is the normal psi for a 03 evo is 19psi or 16 psi ?, because my reading after instal the Helix IC kit is 12 psi and I dont have a MBC..
Old Sep 9, 2005 | 12:25 PM
ez's Avatar
ez
It is "normal" for the stock 03 to hit ~19 and trail off to ~16 in the top half of the RPM range...
