Alky w/o AEM?
Old Sep 8, 2005 | 05:17 AM
nnorris7413's Avatar
Alky w/o AEM?
Who here is running alky without aem? Im getting cams, then after that im thinking of making my next nod alky. Would it be ok to run it on the safc until i get aem in the somewhat distant future?
Old Sep 8, 2005 | 06:16 AM
vrrrm...psss's Avatar
IMO you might be better off with a flash.....just because you cant directly change timing with an AFC
Old Sep 8, 2005 | 06:20 AM
lexat20's Avatar
yeah you can run alky with a flash the aem is just so you can constantly mess with it to dial in
Old Sep 8, 2005 | 06:31 AM
Cool, does anyone know of anyone running alky with an safc? I just wanna know what the results they got were.
Old Sep 8, 2005 | 06:40 AM
GOKOU's Avatar
Some people are doing it but that will not be maximizing the use of alky. I suggest you get a flash then tweak using safc.
Old Sep 8, 2005 | 07:03 AM
the problem is, i dont wanna pay the couple hundred dollars for a flash if im gonna switch to aem in the future.
Old Sep 8, 2005 | 07:05 AM
GOKOU's Avatar
When's the future? If it's going to be long then go for flash and enjoy it for now if not then wait for AEM
Old Sep 8, 2005 | 07:07 AM
rlazer5000's Avatar
Hold off on the alky until you have all the supporting mods for it, that is, a proper EMS. If you plan on switching to AEM in the future, wait until then to get alky. And shouldn't you be in school? Tisk tisk!
Old Sep 8, 2005 | 07:12 AM
I am in school right now. Oh yeah, would i need new injectors for alky?
Old Sep 8, 2005 | 07:17 AM
rlazer5000's Avatar
Nevermind
Old Sep 8, 2005 | 07:25 AM
GOKOU's Avatar
If you're planning to stick with stock turbo I'd say no upgrade injector require. If you're upgrading turbo then go 680 or higher depending on the turbo.
Old Sep 8, 2005 | 07:27 AM
4ringturncoat's Avatar
Actually you use LESS fuel on Alky so you might be ok on the what you have. If you are going to run alky and no flash I would run the SAFC on MAP and not TPS. It is best to do a Flash for the alky though.
Old Sep 8, 2005 | 07:34 AM
xiaoni420's Avatar
to reiterate what others have said, no you do not need larger injectors while running alchy. actually running alcohol is a way to prevent you from Having to buy larger injectors. You lessen the duty cycle of the injectors because you are adding additional fuel. so the stock injectors are more than enough on the stock turbo.
Old Sep 8, 2005 | 07:45 AM
Ted B's Avatar
No injector upgrade required. Alcohol injection actually reduces injector duty, so the stock injectors are fine.
No standalone is required for alcohol injection, but you WILL need at least means of recalibrating the fuel curve and dyno tuning time if you want to get the most from what you spend on the alcohol injection kit.
Old Sep 8, 2005 | 07:50 AM
rlazer5000's Avatar
Well then, I guess you don't need upgraded injectors. I forgot that alky uses less fuel. Oh well, I shall retract my previous statement.
