Any TITANIUM Downpipes out there?
Old Oct 7, 2005 | 01:55 AM
NocturnalEVO's Avatar
Just wondering, are there any full titanium 3" titanium downpipes available from anyone?
Old Oct 7, 2005 | 02:59 AM
astondg's Avatar
I think there was a thread recently about titanium not being able to handle the heat that close to the turbo. It is supposedly more suited to the bits from the cat back.
Old Oct 7, 2005 | 03:10 AM
oh okay, thanks for the headsup
Old Oct 7, 2005 | 03:49 AM
astondg's Avatar
You might want to search for it and check. I might not have read the whole thing, I can't remember now. Actually I just tried a search and i can't even find the thread anymore, maybe I dreamt it . I guess they make titanium valves and the would have to handle a bit of heat. Maybe I should just shut up now.
WAIT! read this thread: https://www.evolutionm.net/forums/sh...=titanium+heat
FYI Titanium is not recomended for DP applications with sustained temps over 1600 high pressure.
(taken from Burns Stainess)
Based on its price and availability, it is hard to believe that titanium is the ninth most abundant element in the earth's crust and comprises 0.5% of the earth's crust.* In fact, titanium is more plentiful than copper, zinc or lead. Though the supply of raw ore is nearly limitless, it is extremely difficult and expensive to produce.* Titanium is a unique high-strength alloy that has excellent corrosion resistance, is extremely lightweight and has excellent high-temperature properties.
Titanium has been of strategic importance in the aerospace industry having been used in aircraft engines, airframes, missiles and spacecraft.* It has also been used extensively in industrial applications where strength and corrosion resistance is of utmost importance including petrochemical refining, nuclear waste storage, power generation and pollution control
Since becoming commercially available in the 1950's, worldwide production of this exotic, "space age" metal has grown to over 50 million pounds annually, and is available for many consumer products including bicycles, computer cases and motorcycle exhausts.* It is expected that as processing technologies evolve and as production capacity expands, titanium will become more economical to use.
In addition to commercially pure (CP) titanium, there exist numerous titanium alloys that are available to industry.* Titanium alloys are generally categorized as alpha, alpha-beta and beta alloys. The alpha alloys exhibit good weldability and have excellent strength characteristics and corrosion resistance due to presence of aluminum. 3Al-2.5V is an alpha-type titanium alloy used for consumer products, sports equipment and aircraft ducting.* Alpha-beta alloys contain beta-stabilizing alloying elements that result in heat treatable alloys, significantly increasing their strength. 6Al-4V is an alpha-beta alloy that has become the "workhorse" alloy in aerospace applications. This alloy offers high-strength, good weldability and fabricability. It is used for airframe components, ballistic armor, sports equipment and space vehicles.* Beta alloys can be heat-treated to very high strength levels due to the high percentage of beta-stabilizing alloying elements. These alloys are used for components such as aircraft landing gear and petrochemical production components.
Burns Stainless uses Commercially Pure, Grade-2 (CP-2) titanium for tubing bends. With a room temperature elongation of 20% at room temperature, CP-2 tubing can be bent on a mandrel bender.* CP-2 also exhibits excellent weldability and can be used for fabrication of exhaust headers in limited applications. Burns Stainless recommends CP-2 titanium for exhaust headers in applications where weight is a primary concern and where significant air-cooling is available such as for motorcycle headers.* It is also excellent for under-car exhausts.* Burns Stainless does not recommend using CP-2 titanium for turbocharger headers or where high exhaust temperatures are present.* 321 stainless steel and Inconel are better choices for these applications. The tubing specification is ASTM B338-99 - Standard Specification for Seamless and Welded Titanium and Titanium Alloy Tubes, for Condensers and Heat Exchangers.
CP and most titanium alloys can be welded using a variety of welding processes.* Burns Stainless recommends that titanium be welded using gas tungsten-arc (GTAW), also known as TIG welding. Although still prevalent today, it is not necessary to use an inert chamber or glove box when welding titanium. By following the welding procedures outlined in the header construction tips article, successful welds with titanium are possible.* As previously mentioned, proper gas shielding is essential for welding titanium.* It is important that the inert shielding atmosphere is maintained until the metal temperature cools below 800F this can be accomplished with a good post-purge.* An argon back-purge is also essential to ensure a proper weld with titanium.* Solar Flux is not recommended for welding titanium.
Weld color can be a good indication of weld quality. Proper gas shielding is evidenced by bright silver welds. Dark blue or white powdery oxide on the weld is an indication of an improper gas purge and a poor weld. The importance of surface cleanliness and the correct use of shielding gas (argon is recommended) cannot be overstated. Since molten titanium reacts readily with oxygen, nitrogen and hydrogen, exposure to these compounds during welding can adversely affect weld properties and must be minimized. Titanium cannot be welded to most other metals due to the formation of embrittling compounds that can lead to cracking.
it might be best to use a SS DP then a Ti catback IMHO
Aston
Old Oct 7, 2005 | 03:51 AM
lol
Old Oct 7, 2005 | 10:06 AM
Mike@Forge's Avatar
A-Spec (vendor here) is currently testing designs for a 76mm (3") titanium downpipe and a titanium exhaust manifold. They have apparently been using both for quite a while now with no issues whatsoever.
They already offer a 76mm (3") cat-delete/testpipe too.
Once they finish the downpipe and manifold, I will probably buy the entire set!
Old Oct 7, 2005 | 11:44 AM
value's Avatar
Auto Produce Boss makes a Ti downpipe.
Old Oct 7, 2005 | 11:46 AM
any more info on it value?
Old Oct 7, 2005 | 02:38 PM
Mike@Forge's Avatar
www.ap-boss.com is the website, but there is nothing there of any consequence!
What you can see, however, looks like decent quality parts, but I can't imagine it's cheap. Usually, smaller Japanese shops like that produce very low volumes of parts and subsequently, their prices are higher.
Old Oct 7, 2005 | 03:26 PM
dolemite45's Avatar
The downpipe would have to be fairly thick, with some impeccable welds for that kind of heat.
I've heard of a couple guys breaking exhaust hangars and welds on those full titanium catbacks you see from Greddy, JIC, and Magnaflow (i believe they are made in the same Taiwanese factory, as they all look the same)....and those are catbacks, further away from the high heat coming off the turbo.
You want a good reliable downpipe? Get an inconel downpipe.
Stainless steel is the best way to go for reliability. You can't beat it for price, performance, and weight. I'm happy with my Tanabe SS dp. 15k with it on, and no problem. Feels like it weighs about 7 lbs, which isn't much.
Old Oct 7, 2005 | 03:48 PM
Any info on an inconel downpipe?
btw is your tanabe a full 3"?
I'm looking at getting a full 3" exhaust, but i'm piecing it together. So just wondering what's a good inexpensive 3" downpipe
Old Oct 7, 2005 | 04:10 PM
dolemite45's Avatar
No one makes a full inconel downpipe...not for street cars anyhow
Inconel is used for full headers/exhausts on F1/LeMans cars. Inconel is one of the strongest materials out there for heat...very good, trick stuff...hard to come by, and even harder to fabricate.
The Tanabe is a 70mm (almost 3"), clears stock cross member, and works with aftermarket too. Got mine for about 2 bills.
IMHO Titanium is mostly hype, considering the potential reliability issues if the material is too thin, and the way full Ti systems sound (loud! and twangy!.
Old Oct 7, 2005 | 05:25 PM
NDgsx's Avatar
Originally Posted by dolemite45
(i believe they are made in the same Taiwanese factory, as they all look the same.
I wouldn't be suprised, it's not cheap to make a whole welding station in a sealed room filled with argon. Welding titanium in regular atmosphere is a royal PITA without contamination from what I hear. Anytime you see discoloration around a ti weld it's a weak contaminated weld.
Old Oct 7, 2005 | 05:36 PM
ray3328's Avatar
[QUOTE=dolemite45]The downpipe would have to be fairly thick, with some impeccable welds for that kind of heat.
The Ti exhausts come with stainless hangers. I've had my Magnaflow Ti for a while now and haven't had any problems with it as a matter of fact if I had to do it again I would.
Old Oct 7, 2005 | 10:10 PM
value's Avatar
Boss Ti pipe is available in 70,75, 80MM sizes. Weight of the 80MM Ti pipe is 1.4 Kilos. Here is a pic and yes it is expensive.
