Timing belt tension tool?
Old Oct 7, 2005 | 02:39 PM
JasonS's Avatar
is it needed to change the cam gears? I'm not changing cams, just the gears.
I did a search, and didn't see if there was another option.
thanks
Old Oct 7, 2005 | 02:43 PM
matt55's Avatar
yes
Old Oct 7, 2005 | 02:50 PM
Cajun Power's Avatar
Ditto (yes).
You need it to create slack in the belt to get the gear out. If you don't the gear is gonna be under tension when you take the bolt out. You will get screwed it you try it with out the belt slacked off.
Old Oct 7, 2005 | 02:53 PM
JasonS's Avatar
thanks for the info...now I'll try to get my local dealer to let me borrow it for the weekend...
Old Oct 7, 2005 | 03:05 PM
I just went to a hardware/bolt shop and got a piece of threaded rod and two nuts. put the nuts in a bind on the end of the rod and for $2.10 I had the $45.00 tool. Do a search. I know the specs are on here. I posted them...
Just take your time screwing the tool in our you will bend the hydraulic tensioner.
Old Oct 7, 2005 | 06:29 PM
DrEvo's Avatar
Here you go guys, AMS sells it, below is the link. Also, make sure you get the right strength for the rod if you will be making your own. Trust me, several of the ones that mitsu says to buy on their manual, have broken on me. The one I have now is strong. You can definitely make your own, just as "Cajun Power" said, but make sure you get the correct rod strength and you will be golden.
Here is the link:
Its to the bottom of the page.
http://automotosports.com/index_evo.asp
Old Oct 7, 2005 | 09:45 PM
elhalisf's Avatar
no you dont. all this part does is compress the timing belt tensioner so you can put a pin in it.
all you do it loosen up the pulley (to the right of the tensioner) to release the pressure off the tensioner and to loosen up the belt. then take of the tensioner. you then use a vice to SLOWLY compress the tensioner and put a pin to hold it.
i have done this a number of times, and never had a tensioner fail on me.
Old Oct 7, 2005 | 10:22 PM
KazzEvo8's Avatar
I saw it on lancershop.com. I don't know about it being in-stock. Good luck!
svt_lightning01
Feb 9, 2011 01:10 PM
GBAILEY472
Jan 31, 2011 10:13 AM
kingkorea76
Aug 12, 2010 09:52 PM
t.e.s
17
Sep 20, 2006 06:45 PM
mikiblueeyes
22
May 18, 2006 11:58 AM
