Hallman mbc not boosting to 21
I was messing with it one day cause i was boosting at over 25psi. I then tried to adjust it back to 21 and now it wont go over 16 - 18 psi on any gear pull..The MBC knob is turned all the way out...what can be the problem...?
Check for a boost leak which may have developed after you over boosted
Also - as a way to diagnose the MBC - pintch the line to the MBC closed shut and watch in 2nd gear of the boost spikes up higher - just let it shoot up qucik do not hold a high boost
lol thats the reason...i thought it was all the wayout for max boost..i will try that and see what it does
Again, if it's all the way OUT, it should only show 11psi. There's no way it can show 16-18psi when set to minimum boost, so that's another issue.
all the way out it was showing 13-14 psi...that 16-18 was in a a little bit..then I turned it all the way in and the turn it out a little..spiked it to 28 - 30spi...just made some adjustments pulling it out..got it holding 21 psi again steady
all the way out it was showing 13-14 psi...that 16-18 was in a alittle bit..i just took it out...turn it all the way in and the turn it out a little..spiked it to 28 - 30spi...just some adjustments pulling it out..got it holding 21 psi again steady
TonyG
18
Apr 2, 2007 09:59 AM
