fuel cut or boost cut?
Old Oct 26, 2005 | 08:37 PM
vegasboy301's Avatar
well, im having quite the dilema with my vehicle... i keep hitting this cut. i dont know which if fuel or boost.
here are the symptoms. i WOT it from any gear but 1st at low rpm's (around 3k) then when it hits about 4 or 5 my car just like cuts boost or fuel or something. and then feels like i hit a wall or something, then continues through the rpms. but if i downshift and the rpms are above 5 and go through the gears it wont happen ) boost i believe goes to 0? idk
i had this problem before but was solved by turning down the boost to about 20psi instead of the normal 21. (ran 12.5@108 with 20lbs of boost)
since then, all ive got was a fuel pump.. (could that be it?)
current mods:
3" Helix TBE
MBC set at 19.5
buschur intake
walbro fuel pump
greddy type-s BOV
safc-II with buschur settings
i was thinking maybe it could be that with the fuel pump increse i would need bigger injectors?
also i had a clutch installed, so maybe a boost leak? idk...
any help would be greatly appriciated.
Old Oct 26, 2005 | 09:03 PM
Warrtalon's Avatar
What is your tuning device? What boost gauge do you have?
Old Oct 26, 2005 | 11:03 PM
oh... i have an safc-II with buschur settings...
but the this wasnt a problem even with the safc before i put in the fuel pump and installed the clutch... so im not blaming the safc because i ran perfect before...
Old Oct 26, 2005 | 11:06 PM
precisi0n's Avatar
sounds like boost cut... im having the same problem... Its because of the cooler weather i think... Its not 100+ anymore
Old Oct 26, 2005 | 11:33 PM
well i thought that as well. but really... its happening too much. and i lowerd my boost to 19!!!! thats not normal
Old Oct 27, 2005 | 11:43 AM
anyone know?
Old Oct 27, 2005 | 11:53 AM
gonzo's Avatar
Push it off a cliff.
Old Oct 27, 2005 | 11:56 AM
Nez136's Avatar
Fuel cut, get a flash or get rid of the SAFC and go with some sort of a EMS
bigjhoney's Avatar
check for boost leaks
Old Oct 27, 2005 | 11:58 AM
berkel's Avatar
Hi,
I didn't see current mileage on your car?
I had the exact same symptoms plague me last winter. For several months, I drove "around" the problem and never went WOT near TQ peak because I would get a hiccup. It really sucked.
Anyway, I did various things to help, but none of these cured my problem:
Lowered boost.
Leaned out SAFC slightly.
Tightened all clamps on IC hoses, then switched to T-bolt clamps, then switched to Samco hoses.
Tried NGK coppers (BPR7ES and BR7ES) with various gaps. ~.026 worked better.
Finally, I switched my Magnecor wires back to stock, and the problem disappeared. Basically, the Mangecors did not have perfect fitment, so I was getting misfire. Currently running stock wires and NGK BPR7ES and haven't had the problem in almost a year.
Not sure if you have stock wires? Look at plugs and gap or try swapping wires to see if it helps. If not plug/wire related, double check for boost leaks.
Good luck.
FB
Old Oct 27, 2005 | 12:05 PM
Originally Posted by berkel
Hi,
Lowered boost.
Good luck.
FB
i have stock wires.. ill try that. and check for boost leaks in the mean time.. im hoping thats what it is thanks...
Old Oct 27, 2005 | 12:06 PM
push your slow evo off a cliff alex.
Old Oct 27, 2005 | 12:10 PM
gonzo's Avatar
Ha, I'm not the one having problems b itch.
Old Oct 27, 2005 | 04:45 PM
joeymia's Avatar
Your hitting the fuel cut. Try switching back to the stock airbox because the intake may cause higher MAF readings. If switching back to the stock airbox helps keep that until you get flashed.
sebas-chan
Apr 25, 2018 06:03 AM
Ksay3
Dec 9, 2015 03:26 PM
butte
Nov 12, 2015 04:23 PM
emotart
Jan 4, 2011 05:20 AM
AlwaysinBoost
42
Oct 30, 2005 07:16 PM
