Which WASTEGATE ACTUATOR to Get?
Well my stock Wastegate Actuator has been messed up for some time now, I'm trying to look into getting a new one.
Now I see 2 aftermarket ones options available to me.
The FORCED PERFORMANCE wastegate actuator:
http://linux.forcedperformance.net/m...ode=Lancer_EVO
for $165
and
The FORGE MOTORSPORT wastegate actuator:
http://www.forgemotorsport.com/conte...roduct=FMEVACT
for $160 from Stikiller.com (http://www.stikiller.com/product.php...age=1&featured)
The price difference is really nothing. The fact that the FP one looks like stock doesn't benefit me much as my car basically has no warranty anymore lol..
I was wondering which one is better? Or if there are any reason not to get one over the other?
Let me know what you guys think.
Thanks!
for $165
and
Thanks!
I personally can vouch for the Forge Motorsport unit. It holds boost much better than the stock actuator, combined with the UNOS boost controller taper is cut to a minimum. The unit itself is very sturdy being completely billet. It also looks great and the springs can be swapped out for different base boost levels.
Although I run the FP unit, there is little denying the adjustability of the Forge... However, I've not needed, nor wished for any adjustability in my wastegate actuator. All you can adjust over the FP actuator is the spring pressure. I've got my actuator set to hold 18-19psi on spring pressure alone.
From what I know four things help kill the boost taper- I've tested two...
1. Stock BOV (possibly the biggest factor)- the stocker is plastic and leaks
2. Adding an QUALITY Mbc- this assists in the amount of bosst that the wastegate see's.
3. The wastegate itself.
4. Reflash
4. Reflash
We sell the Forged wastegate actuator and one of our own. The forged unit is adjustable and comes with a variety of springs, plus the rod is still adjustable. Nice if you are going to be changing boost levels and such.
The other we sell is a modified stock actuator that is actually taken apart and has a heavier spring installed. This actuator is rated at 26 psi, very heavy duty. Recommend it for race gas or alky use only. You cannot tell that it is not stock.
David Buschur
www.buschurracing.com
David Buschur
So we basically have 3 to choose from depending on ones needs
- Forge WG act - adjustable
- Forced Performance WG act - adjustable, looks stock
- Buschur WG act - Stock housing and diaghram with stiffer spring, looks stock, not recommended 23 or less psi boost control.
As a little background on our units:
Base Actuator Spring Pressures Available:
Green Spring - 5-10 PSI
Yellow Spring - 10-15 PSI
Blue Spring - 14-18 PSI
Red Spring - 19-24 PSI
(Evo actuators are now built with the 19-24 PSI spring. Other springs are available individually for a cost of $16 each or swapped into an actuator at the time of ordering at no additional charge.)
A manual or electronic boost controller may still be used to acheive a higher overall boost setting.
Other Features:
Full 6061 Aluminum Body
Full 6061 Aluminum Bracket (Evo 8 Specific)
Full Stainless Steel Rod and Other Harware
Polished Finish
2mm thick Neoprene Diaphragm
Fully Adjustable
Fully Rebuildable
LIFETIME WARRANTY
Other Features:
Polished Finish
Fully Adjustable
Fully Rebuildable
LIFETIME WARRANTY
