GT35R clutch suggestions
Hi guys My question is what clutch should I get for my setup witch is , 272/272 , XEDE with SMART all the Bolton's and a RNR GT35R Turbo kit , I don't do much of Drag Racing so that is basically street driven car with occasionally 2nd-4th gear pull ( on closed course ) any advise is appreciated thanks .
Originally Posted by RREvo
What about ACT will it be strong enough ?
Exedy Twin will be capable of holding around 500whp. However, I would highly recommend the carbon carbon if you have the extra cash. It will last longer and grab better when its heated up. I have the Exedy on special right now if you are interested.
Thanks,
Tom
Thanks,
Tom
we went with the Tilton ceremettalic twindisk for our car. due to its bellows style replacement throwout bearing. this new throwout bearing eliminates "retaining clip" problem that we seen happen with the pull type slave cylinder.
kirk tells me its good upto 600ftlbs...
i know your question is for a dd. but, i figure the more options the better
also, when looking for a clutch, its best to determine the amount of tq you are looking to hold, not so much the size of the turbo, or the amount of hp.
we don't sell clutches, but feel free to PM me with any questions you might have.
you're getting a lot of recommendations for some pretty expensive clutches....
The entry level street clutches (single disc, organic) from Exedy RPS, and ACT will hold about 500 ft. lbs. of torque. If this is within your goals, anything more will be by choice, not because you'll need it.
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
I am very happy with my ACT. I daily drive it and have no complaints. It's all a matter of what you want to spend.
