How much boost in winter?
Hey, i was just wondering how much boost you guys were running in the snow. We got the first real snow of the season here and i was boosting 20 pounds and i think that i should turn it down a bit seeing as how i cant use the boost to its full potential right now. I still want to have enough boost to spin the tires during a slide. So whats an average boost level for winter driving?
why turn down the boost? Maybe just drive more cautiously in the snow, rain and ice?
In fact, you could probably be running a little more boost on pump gas as it is.
Either way, enjoy the winter and the great car!
In my EVO, after I changed back to the stock catback and the weather got cooler, the car was running much leaner (in the 12.XX range) and boosting to 23 p.s.i. Needless to say, it was retuned to a more safe AF ratio and lower boost.... Amazingly, the power went up a little bit with the safer tune.....
Originally Posted by MM Racing
I turned mine down because I can't have it much higher then 18 with out hitting fuel cut, when the temps dip below 30F.
I'm tapping 23psi and dropping to 21 on 93 octane this winter. I hooked up my wideband the other night and the a/f was sitting at 11.5 straight across in 3rd gear and 11.2 across in 4th. I do have a walbro though.
