[Vid] Boost on launch
Old Dec 20, 2005 | 06:04 PM
Crufty Dusty's Avatar
Originally Posted by ct9a gsr
What EMS are you using, what turbo, what fuel, and what settings?
Be VERY careful building that much boost on a 2-step anti-lag system... one small mistake and you can see some catastrophic explosions...
BTW, I've built about 2bar before using anti-lag at 0mph.
Stock turbo, pump gas, MoTeC... minimal fuel cut and ignition retard. It's programmed in such a way that when the intercooler switch is on auto, it selects the first map and activates the spray bars. If the intercooler spray light blinks, then the second map is selected. The best part about all this is that it all looks completely stock.
Yep you can practically build any amount of boost you want, but as you pointed out doing 2 bar on pump gas would be pretty dangerous.
The car is still on stock transmission and on its 4th clutch (stock, an OS Giken which lasted the longest and 2 Ogura carbon-carbons)... as for video of actually launching, it wouldn't be very interesting from an in-car point of view...
Old Dec 20, 2005 | 07:01 PM
Ang Wen Yan's Avatar
He got alky,so it's safe.
Old Dec 20, 2005 | 08:58 PM
joeymia's Avatar
I would like to see you actually launch it. I can build 20lbs just using the MSD DIS-2 as well. I want to see how it handles all the extra gas. It would probally just bog hard if you tried to launch. I fooled around with different setups and I liked 12-14lbs best. I don't get any bog and it launches very hard.
Old Dec 20, 2005 | 09:04 PM
johnny's Avatar
Registered User
What kinda BOV are you using sounds wicked
Old Dec 20, 2005 | 09:15 PM
jbrown's Avatar
What MoTeC do you have? I didn't know they had 2 maps??
Old Dec 20, 2005 | 09:37 PM
vegasboy301's Avatar
Launch It
Old Dec 20, 2005 | 10:12 PM
joeymia's Avatar
didn't show the launch or anything after the 20psi because it most likely stalled. The amount of fuel the engine will use when it sees 20psi at no load is insane.
Old Dec 29, 2005 | 08:02 AM
diablors's Avatar
Like everyone else I wanna know what kind of BOV is that. It different then any BOV I've heard
Old Dec 29, 2005 | 08:50 AM
timzcat's Avatar
Wow, what's the point?
I can build almost 20 psi on a stock turbo using the EcuTek flash and for everyone asking it will launch just fine like that.
