exhaust leak
Old Dec 25, 2005 | 08:57 PM
t88h supra's Avatar
exhaust leak
I have an exhaust leak between my downpipe and tubular o2 housing. I went to buy a gasket and when it came in they also had an exhaust manifold gasket. They tried to say I would have to replace both to do a proper install. I helped a friend install a downpipe onto a stock o2 housing and we didn't do this. I've never heard of replacing both. You can just replace the one gasket, right?
Old Dec 25, 2005 | 09:04 PM
Deepseadiver's Avatar
What is a Tubular O2 housing? Do you mean aftermarket O2 housing or a tubular exhaust mainifold.
Your post isint clear as wher your leak is at. It will be two gaskets if its at the header.
Only one if its at the downpipe.
Block/header/O2 housing/downpipe
Old Dec 25, 2005 | 09:11 PM
vboy425's Avatar
i tihnk he meant the o2 housing to the Dp. get an Doughnut gasket. iot should fixed the problem
Old Dec 25, 2005 | 09:23 PM
t88h supra's Avatar
The leak is between the aftermarket o2 housing and downpipe.
A 3" donut gasket, correct?
Old Dec 25, 2005 | 10:36 PM
SuperchargedGTZ's Avatar
that is correct...but it wont make a difference in performance
Old Dec 26, 2005 | 07:17 AM
t88h supra's Avatar
Ya I know. I can't let air from outside into the cabin of the car without dying of carbon monoxide poisoning at this point
Old Dec 26, 2005 | 08:03 AM
GOKOU's Avatar
If you find a 3" donut please let me know.
People say an exhaust leak at the DP doesn't effect performance but to me it looks like it does. A leak effects back pressure. Maybe I'm just paranoid.
