Another Tilton Install
Old Jan 11, 2006 | 01:31 PM
Jack @ EvoStore's Avatar
Another Tilton Install (Who has 56K anymore anyway?)
We wrapped up another Hybrid install for a local. Here are some pictures from the process.
Evo on the lift
Stock clutch and flywheel
Hydraulic release bearing installed
Lines run through the factory vent port
This helps prevent any chafing on the case
Feed line
Bleed line
Bleed line close up
Tilton Hybrid installed
Old Jan 11, 2006 | 01:36 PM
Curt@MrLed's Avatar
Former Vendor
mmm. im not sure which is nicer.. the warm air you have there, or the hyd. release bearing.. just curious, how much for that..
Old Jan 11, 2006 | 02:00 PM
Sorry this is a semi-repost. The customer actually posted his own thread here.
Farmer - we don't normally sell the hydraulic release bearing seperately. The Tilton Evo Hybrid sells for $1625.
Old Jan 11, 2006 | 07:40 PM
dryad001's Avatar
Manny's clutch finally gave out looks like.
Old Jan 11, 2006 | 07:47 PM
Drifto's Avatar
I think he said it was a metalic and not a hybrid. You may want to clear that up with him.
Old Jan 12, 2006 | 10:48 AM
Check out the other thread I linked to above. He says, "I got it done at the Evostore Shop. The guys there are great. I got the Hybrid Tilton. It is cerametallic/organic."
Old Jan 12, 2006 | 05:44 PM
Drifto's Avatar
My bad. I must have misread that.
Old Jan 13, 2006 | 09:44 PM
04AWDTURBOEVO's Avatar
Thanks Jack, to you guys for the nice and wonderfull install.
Sup, Mike? Yep, the stocker decided to go. Anything over 10 psi and it would skip/jump and slip. Now I got to break in this bad boy and then back to normal boost, 23 psi, lol.
Old Jan 13, 2006 | 11:47 PM
Agent-Smith's Avatar
Why does it look like you kept the stock flywheel?
Old Jan 15, 2006 | 06:18 PM
Here is a pic of a stock flywheel.
Two complete different flywheels.
Old Jan 17, 2006 | 09:51 AM
So is it just the carbon/carbon that has this kind of flywheel?
http://www.tiltonracing.com/incs/ima...?picture=d0061
Old Jan 17, 2006 | 09:50 PM
No, that does not look like the Evo Carbon/Carbon Tilton.
I don't know what application that is for. May be a feather weight version of their flywheel. If it is, it is got to be very light, as the regular wheel is light as it now seats.
Here is a picture of the Evo Carbon/Carbon, a beauty.
Old Jan 19, 2006 | 08:36 AM
That looks more like a featherweight flywheel - more like in the 2JZ Supra triples. The Evo carbon/carbon package is pictured here. The flash makes the clutch cover look bronze, but it is actually black.
Old Jan 19, 2006 | 12:31 PM
btuneallen's Avatar
That is phreaking sexy..
Wayne99gsr
Apr 14, 2010 02:23 PM
dD Spikey
Sep 30, 2008 03:43 PM
EvoIXJDM
56
Jul 7, 2008 09:37 AM
gobagheera
Feb 11, 2008 07:05 PM
CadiLuva
Lancer How Tos / Installations
Apr 6, 2007 10:11 AM
