when should i get the 1st oil change?
Re: when should i get the 1st oil change?
Originally posted by totaleuge
mileage is approaching 1k... when should i start thinking about my 1st oil change??
I concur. I've always done the first oil change at 1k miles on my new (performance-oriented) cars. Since Mobile1 is such a fantastic product, I usually go about 5k between each change, unless the car is being tracked. In which case, oil change after each track session (usually multi-day events).
Hey, Obso...nice to see another Yellow EVO
Rev on,
Leonardo
Rev on,
Leonardo
Re: Re: when should i get the 1st oil change?
Originally posted by Obsoleteasian
I just got mine changed today.. at 1315.. I wanted it earlier but didn't have time to stop by a mitsu dealership for the past week. For some reason my car feels a lot better.. Probably my imagination but **** it. I like my imagination.
i just did mine at 1010 miles... and i feel the same way u do.. it's like the engine sounds different! feels better!..
soon the gauges go in.. then the MBC, then the S-AFC!
Originally posted by OZ_03
I changed the oil on my OZ at 2500, with Royal Purple. Surprisingly, there was a bit of a difference. Or maybe its my imagination like obsoleteasian.
Service schedules according to Ralliart UK
Every 4,500 miles or 6 moths
1. Check operation of all exterior lights
2. Check condition of wiper blades
3. Check auxiliary drive belts for damage/tension
4. Replenish washer fluid level
5. Replenish intercooler spray system
6. Check brake lines for leaks
7. Check rear diff oil level
8. Replace AYC fluids (reservoir+diffs)
9. Replace Engine oil (fully synthetic only)
10. Replace engine oil filter
11. Check brake pads/disks for wear
12. Check tyres for damage/wear
13. Check reset engine idle speed
Every 9,000 miles or 12 moths
1. Check all turbo hoses for damage and security
2. Check condition of the air filter
3. Check cooling systems for leaks
4. Check brake/clutch fluid levels
5. Check battery levels. Replenish if necessary
6. Check f/r suspension for damage and security
7. Check steering system for damage and security
8. Check gear box oil level
9. Check transfer box oil level
10. Check brake/clutch pedals for travel/adjustment
11. Check/adjust hand brake travel
12. Swap tires front to rear (if necessary)
13. Check/adjust tire pressures
14. Check condition of body
Every 18,000 miles or 24 months
1. Replace brake fluid
2. Replace air filter
3. Replace coolants. Check systems for leaks
4. Check HT leads
5. Check drive shafts and gaiters
Every 45,000 miles or 60 months
1. Replace timing belts A + B
2. Replace spark plugs
3. Replace fuel filter
4. Check sencindary air system hoses for leaks
5. Check crank case control system/pipes
6. Check fuel pipes for damage and security
4. Check HT leads
