Any IX's with big turbo?
I want to find out the effect of the MIVEC on the big turbo as far as spoolup and power. And hopefully, compare it to data already obtained on the VIII so that I have a better idea how MIVEC works with upgraded turbo,
If you have upgraded your turbo,
1. What turbo did you go with?
2. At which rpm do you see full boost on pump gas map? (21-22 psi)
3. If you have race map, then when do you hit full boost and how much boost?
4. Power level on pump, race gas
If this topic has been discussed, then flame me, but couldn't find a topic on this after searching. Thanks!
