car cuts off during WOP
Old Feb 14, 2006 | 10:38 PM
chrisalishuss's Avatar
hi all. I just bought an 03 evo with a little over 30K miles. The car has an upgraded garret turbo, (apparently hks cams 272 or 282), 3in exhuast (dp/catback)hks, intake(not sure make), perrin fuel rail, i beleive a greddy oil catch can, greddy bov, and a couple other goodies. I am taking it in to have a third party run a compression check, run dioignostics or whatever to see whats up with everything. I went on a little canyon run to see how she felt and while i was very happy through the twisties, everynow and then boosting in 3rd or 4th it will cutoff and stop accellerating (i noticed the boost guage was at 1.5 bar). it fely like the injectors were reaching thier max cycle or something so i thought that might be the problem. They didnt have a full listof the mods and im in the process of contacting the previous owner to get real list. The "service engine soon" light is on aswell. any ideas of what the problem might be and also a reliable mechanic that can take a peak and see if everything is ship shape. thanks a lot.
Old Feb 15, 2006 | 08:01 AM
Ludikraut's Avatar
You are probably hitting boost or fuel cut.
I'd recommend taking it to RRE (Road Race Engineering) to have it checked out. They are local to you and very reputable.
l8r)
Old Feb 15, 2006 | 08:09 AM
naucrx's Avatar
You might want to start by using an OBDII scanner to see what code(s) your car is throwing.
Old Feb 15, 2006 | 09:27 AM
Steve@NoLimitmotors's Avatar
i dont think there is any such thing as boost cut. Sounds like fuel cut.
Old Feb 15, 2006 | 09:45 AM
stiguy's Avatar
Fuel cut is the worst feeling in the world, feels like u hit a brick wall...........at least in STi's
Old Feb 15, 2006 | 09:58 AM
NY Evolutionary's Avatar
Definitely boost cut. I had the same problem, does not feel like the rev limiter, much harder.Bring it to some one who does reflashing, and they can remove the boost cut. Good luck.
Old Feb 15, 2006 | 10:04 AM
hotrod2448's Avatar
It is probably fuel cut.
The check engine light could be a bunch of things. Catalyst efficiency too low, P0300, or something else. Get the codes pulled and go from there.
Old Feb 15, 2006 | 02:31 PM
Ludikraut's Avatar
Yes there is, on an unmolested stock ECU, you will hit boost cut at approximately 23 psi.
l8r)
Old Feb 15, 2006 | 07:37 PM
thanks for the reply's. any other shops that are reputable or is road race engiineering my best bet?
Old Feb 15, 2006 | 08:02 PM
blkdinan's Avatar
Road Race is your best bet. Outstanding top rate group.
Old Feb 15, 2006 | 09:11 PM
sonicnofadz's Avatar
What the hell is a WOP?
Old Feb 15, 2006 | 09:26 PM
95GSXtoEVO8's Avatar
I take offense to all this WOP talk! lol
I never understood why people call it boost cut though, it's really caused by the ECU seeing the injectors being maxed out and cutting the fuel to the engine for a split second to warn the driver and prevent detonation. I guess because it usually happens when overboosting.
Old Feb 15, 2006 | 09:58 PM
well I think that preventing detonation would be a good thing. if the car is properly tuned, then is it necessary to removethe fuel cut. I think it is beneficial to have something like that, I would rather have that happen then detonate and throw a rod or something.
PS..... WOP = wide open throttle
Old Feb 16, 2006 | 11:36 AM
Oh, I always thought that wide open throttle == WOT
Old Feb 16, 2006 | 12:07 PM
LOL, im an idiot...
Evoryder
Feb 1, 2008 03:59 PM
Jeff_Jeske
Aug 6, 2007 10:41 AM
totalsbl14
Feb 1, 2006 08:26 PM
techause
AEM EMS
52
Aug 17, 2004 12:15 PM
