what next?
Old Feb 26, 2006 | 11:27 AM
zbomb's Avatar
Thumbs down what next?
I have a 05 with the following:Hks dp,rmr 3"cat back,rmr intake,hks 272's, valve springs and retainers,cam gears -3,-3,and ecutek tune. I am only making 270 hp on a dyno dynamics dyno. I am tuned on 93 and boost is solid 22 tapering to 19 at redline. Is there a mod that I have overlooked or does it just sound like a tune that needs improving.
p.s. I know that I need to get rid of the cat but even then it won't gain me more than 15hp. I think it is still low.
Old Feb 26, 2006 | 11:30 AM
EvoJutsu's Avatar
do u have a MBC? i mean if u did then the boost should hold 22 or 21 psi strong till redline???
Old Feb 26, 2006 | 11:38 AM
zbomb's Avatar
no need ecutek controls boost
Old Feb 26, 2006 | 11:44 AM
bluebanana23's Avatar
Isn't the HKS 2.75 inches? Get a hi-flow cat, port and coat manifold as well as the O2 and your 10.5 hotside. Then get alky injection with the lower I/C pipe.
Old Feb 26, 2006 | 11:48 AM
BigAeVo's Avatar
don't dyno dynamics read low? is that custom reflash or through the mail? its probably about right if dyno dynamics read low
Old Feb 26, 2006 | 11:49 AM
Warrtalon's Avatar
an MBC still provides higher boost and holds it better than a flash. I can't imagine relying on a flash to control boost when you go so far as to have cams with upgraded head internals. That's weird, because a nice MBC is only $85 whereas all that other stuff is over $1000 itself...
DDs read really low to begin with, and 15whp from removing the cat is a big jump, too.
Old Feb 26, 2006 | 11:59 AM
zbomb's Avatar
I had a mbc on my last evo and are aware that they are a great way to control boost. From my experience ecutek controls boost just as well, and since I don't ever run race gas I don't need the adjustability of a mbc.
