Turbo kit install???
Old Feb 27, 2006 | 12:52 AM
evoracer32's Avatar
i just recently installed a ams turbo kit and i just fired it up and took it for a spin and i noticed that its has oil leaking out of every spot, i mean now its leaking out of the drain plug and out of the valve cover and out of the oil banjo and i never even touched the valve cover during the install, so is their sumthing that could be hooked up wrong cause this?, thanks in advance
Old Feb 27, 2006 | 01:00 AM
sleeperevo8's Avatar
oil lines on turbo crossed maybe???? cuasing back pressure??
Old Feb 27, 2006 | 03:23 AM
WrX Kila's Avatar
When you received the kit, did you tighten every line before installing it?
Old Feb 27, 2006 | 04:56 AM
gsujeff55's Avatar
thats really strage to have it leaking out of the valve cover if you didn't touch it. I can honestly say i have no idea what to tell you.
Old Feb 27, 2006 | 09:31 AM
3deep's Avatar
If oil is coming out of the valvecover it sounds like your lines are blocked somewhere.Did you stuff anything in the drain hole at the oilpan during install.
Old Feb 27, 2006 | 03:27 PM
evoracer32's Avatar
well after i drained the oil i just put the drain plug back in losely, im not sure were it could be blocked, does anyone no that if the oil banjo bolt that goes to the head has any certain way it has to go, i mean since their are little holes drilled in each side of the bolt
Old Feb 27, 2006 | 03:56 PM
gsujeff55's Avatar
no certain way, because those holes line up with the groove in the fitting that goes around the holes.
OnAll4's
15
Jul 2, 2020 04:55 PM
Chokkan
23
Mar 9, 2017 11:38 PM
dtenev2
Mar 27, 2015 11:53 AM
Demon_ni2
Lancer Aftermarket Forced Induction Tech
13
Sep 26, 2010 03:28 PM
ThEHiTMaN
Dec 25, 2005 09:14 PM
