fuel hose size?
Old Mar 1, 2006 | 04:59 PM
Mr. Boost's Avatar
fuel hose size?
should i use 6an for 8an size hose for the pressure and return lines ? any opinions
Old Mar 1, 2006 | 06:44 PM
TrinaBabe's Avatar
Well considering you didnt post your current HP or your eventual HP goals its kinda tough to tell you. If you are planning on running up to but not past 800 -8 feed is fine and -6 return. If you want to run more than 800 you will need -10 feed and -8 return. These are all estimates also... you could probably run more power but it would be pushing it.
Old Mar 1, 2006 | 06:45 PM
TrinaBabe's Avatar
I wouldnt bother running -6 if your going to actually convert it all.
Old Mar 1, 2006 | 06:46 PM
Mr. Boost's Avatar
oh yea i don't plan to go past 600 if that. so 8 feed and 6 return, thanks for the info
Old Mar 1, 2006 | 06:48 PM
TrinaBabe's Avatar
Np
