HOw come just 2005??
Old Mar 8, 2006 | 04:38 PM
evouser12's Avatar
Hey i know there are many threads on this but i never found the real reason....how coem the 2005 EVO experevice a RPM raise inbetween shifting? i kno all dont do it but i have read a lot do? Iv had mine for 10k miles and hasnt done it and all of a sudden it started...does it happen after you mod your car? is it like a safety issue? does any1 kno the real reason? thanx every1
2005 GG EVO MR
HKS Hi-Power cat back
JIC downpipe
Helix High flow catpipe
JDM EVO MR DV
Turbosmart MBC (21-22PSI)
Walbro 255 Fuel Pump
Greddy Turbo Timer
Apexi Boost Guage
Old Mar 8, 2006 | 04:52 PM
sonicnofadz's Avatar
Try taking your foot off the gas in between shifts. This is also a sign of a slipping clutch.
Old Mar 8, 2006 | 04:56 PM
M3ss's Avatar
Mine started doing this after the TBE !
Old Mar 8, 2006 | 05:00 PM
evouser12's Avatar
mine started doing it after my dynoflash
Old Mar 8, 2006 | 05:02 PM
evouser12's Avatar
Will the RPM raise hurt ur car??
Old Mar 8, 2006 | 05:04 PM
alloyic_rs's Avatar
my 05 rs doesnt do it, my rpm's drop really quick, i gotta shift quick, my only mods are greddy ti catback with test pipe, with stock downpipe
Old Mar 8, 2006 | 05:09 PM
alloyic_rs's Avatar
my dads 05 sti REALLY does it, well they dont rise but when you shift the rpms dont fall at all, its like you're still holding throttle only you're not, its sorta annoying cuz you cant shift as fast as you want
is that what you're talking about?
Old Mar 8, 2006 | 05:18 PM
I suggest you call Al and ask him if he knows. Their is what is called a "rev limiter" programmed into the ECU. It might be a higher than normal rev limiter since your ECU is flashed, but it should limit your rpms to stay under 7800 RPMS.
Old Mar 8, 2006 | 05:28 PM
evouser12's Avatar
nah, ill shift with 3/4 throttle and the rpms will shoot up about 600 sometimes...foot is completey off the gas..dunno waht it is? Al said it was normal in some EVOS, but other people have dynoflashes and do not experience this so i dunno
Old Mar 8, 2006 | 05:32 PM
alloyic_rs's Avatar
hmm, thats odd
Old Mar 8, 2006 | 05:33 PM
evouser12's Avatar
kinda yea i know....how many people experience this...any1 after a dynoflash?? and will this hurt your car?
Old Mar 8, 2006 | 09:55 PM
kf6ytc's Avatar
search guys......... this is a factory 'feature' on all 05-06's........ It basically keeps the throttle body open after u let ur foot off of the gas... You will notice that sometimes the car slows down when you decell, and sometimes it maintains speed (and AFR)..... you will see the rpm's maintaing themselfs at like 5k with your foot off of the throttle, and the clutch PUSHED IN! , this is due to the clutch switch being disabled (launch control).
This whole 'feature' is designed to lower emissions.
-TJ
Old Mar 8, 2006 | 09:57 PM
TTP Engineering's Avatar
2005+ ECU programming.
boricuaboy2005p
Northeast Region
12
Jan 8, 2010 05:48 PM
s3an831
Lancer Troubleshooting
Sep 18, 2009 04:26 AM
BABYEVO1
40
Apr 19, 2007 02:43 PM
flip_EVO
Southeast Region
18
Mar 19, 2007 01:23 PM
evouser12
15
Feb 13, 2006 08:21 PM
