Help diagnosing a friends Evo
One of my friends has an 03 with 25+ miles on it. Recently he started getting a ticking sound at low rpms. He pulled out the spark plugs and there was oil on one of them. He has a tbe, flash, safcII and a mbc. He was denied at the dealer today and they didnt want to look at it bc they said fuel had gone inside the spark plugs. So what can this be? Spun bearings? Piston? Damaged seals?
Originally Posted by Stew
What has he been running for boost? has the power dropped since he noticed the ticking (if he has gotten on it) ?
Originally Posted by stevEVO8
Im thinking he should do a leak down test to see what is going on with the oil on the plug. Then start looking into other possibilities.
Unusual Ticking is serios
Originally Posted by C6C6CH3vo
Fuel cant really enter a spark plug, but a leaking injector can cause fuel to to get in the area of one of the cyc/chambers.
Just be careful, I saw someone slice his hand to the bone opening a filter.
Think about the fuel plug thing, any fuel on the plug will immediatly vaporise when engine is running. The residing fuel/oil whatever seems to have gotten there after eng shutdown - I may be wrong though.
Good luck with your freinds car.
Originally Posted by TTP Engineering
Put new plugs in and drive it a mile to the dealer.
Ohh ohhh and something else, take the oil filter pull it and then go get one of those cool cutters for cutting the filter apart.
Cut it apart and look for shavings etc.
Make sure that he isn't driving the car before he does this check. The more driving the bigger the problem can get. If there is no shavings then I would say a lifter may be ticking or it just may be a clogging injector making more noise.
i would think the piston ring went out on the cylinder with oil in it, probably because the arc on the spark plug tip broke? like ttp said, put new spark plugs in, then drive it to a dealership. or somewhere to get a compression test, and a cylinder leakdown test done. but if there is oil on the spark plugs, then that means that the cylinder is not sealing properly and oil is getting past, such as bad piston rings. do the tests, and you should know your problem
