HKS DLi 2
Old Mar 16, 2006 | 03:19 AM
wspy's Avatar
HKS DLi 2
I've have the HKS DLi 2 installed on my car for a few months now and its been working great until recently when it stopped firing #2and 3 cyl.
Trouble-shot it down to a faulty harness! i changed over mine with another which worked.
Anyone ever had a harness go bad just like that?
Can the harness be bought separately?
Or can it be fixed?
thanks
Mark
Old Mar 16, 2006 | 03:59 AM
4ringturncoat's Avatar
Check your connections are clean, they should be able to self wipe so just plug and unplug then a few times to see if that helps, if not get a ohm meter and check each wire in the harness. you might have a broken wire or bad joint were they split the wire for the coils.
Old Mar 16, 2006 | 04:43 AM
wspy's Avatar
Ok, did all the connection cleaning already with nil results. I'm gonna do the resistance check later. I was feeling along the cable under the protective covering and felt some junction type "bumps" and was wondering what they were!
Old Mar 16, 2006 | 10:41 AM
Rudy's Avatar
I just bout the DLI II. Anyone have pictures or a write up on the install. I hear it's easy but I'm not sure how to connect it.
