compresion test pretty bad, but how bad is it?
Old Mar 18, 2006 | 10:50 AM
o4whtevors's Avatar
allright guys i have done 2 compresion tests over the past week. the first one was cold witch is'nt a good test but might have some relavance
test #1
#1=180
#2=180
#3=160
#4=180
so that did'nt look good but considering it was a cold test i thought eh, its not that bad either. i thought the compresion would come up at operating temp but it did not, it whent down
test#2
#1=180
#2=180
#3=130
#4=180
so now i am left wondering is this most likely a valve starting to become an issue? the car burns no oil, i can go 3k miles and not add once with no change to the dipstick reading, has no metal shavings in oil what so ever, and still seems to be running pretty good. i do have 272 cams so that might have contributed but i am not sure, what do you guys think?
Old Mar 18, 2006 | 01:45 PM
WillEatUrSTi's Avatar
Well besides that one bad cylinder the rest are really good. I don't think it's a valve because if you have an open valve you'd get 0 compression. Try adding some oil to the cylinder and retest see how it affects your bad cylinder. The cams arent to blame reguardless and if they were they'd affect all cylinders. Good Luck.
Old Mar 18, 2006 | 01:52 PM
Curt@MrLed's Avatar
Former Vendor
add some oil, if the number goes up, its a ring.. if it doesnt its either a headgasket, or valve problem..
Old Mar 18, 2006 | 03:49 PM
A418t81's Avatar
Do you have an 03? If so, its a very, very common "issue" for cyl 3 to be 20 psi or so lower than the others. Try checking compression a few more times and make sure you have the throttle plate 100% open when doing it.
Old Mar 18, 2006 | 04:08 PM
Curt@MrLed's Avatar
Former Vendor
plate open and closed does no make a difference.. but my 03 ran 150 to 160 across the board.. so in a sense your doing better than i was..
Old Mar 18, 2006 | 04:38 PM
Event-Horizon's Avatar
My car has the same "problem". Cylinder #3 generally runs hotter than the other cylinders, so in turn it may be a bit tougher on the rings. It's really nothing to worry about if the car runs good. My Evo puts down roughly 350HP on a Dynojet with pretty much the same results as yours.
Old Mar 18, 2006 | 04:56 PM
o4whtevors's Avatar
i am sorry, i have added oil to #3 and there was no change what so ever. also its funny that some one mentioned this being common in 03's as i tested my buddies 03 today and got the same exact results lol. my car is an 04 by the way.
Old Mar 18, 2006 | 04:58 PM
Curt@MrLed's Avatar
Former Vendor
03 and 04 motors seem to have all the probs.. where 05 and 06 do not.
Old Mar 18, 2006 | 05:02 PM
o4whtevors's Avatar
hey, ill take a bad valve over a spun bearing any day of the week.
Old Mar 18, 2006 | 05:11 PM
mchuang's Avatar
Well I have an 03, 35000 miles, and my comp test shows 180 all the way across..just did it 2 weeks ago.
Old Mar 18, 2006 | 05:18 PM
Widebandphillip's Avatar
throttle plate open always.
Old Mar 18, 2006 | 06:29 PM
C6C6CH3vo's Avatar
How many time are you supposed to turn the starter?
My #'s increase until I reach 7 starter turns - 190-191-190-194 (every time).
If I do 4 turns, it's like 10 psi less on ea.
Also, after four turns I allways get a pop!. Is that normal?
Old Mar 19, 2006 | 06:01 AM
mchuang's Avatar
your probably about 190 across. that is very good. The pop noise is normal. I see lots of hi comp hondas hit about 300 lol and it always pops because the guage is maxed out.
Old Mar 19, 2006 | 08:46 AM
dashiet's Avatar
i did my comp test last week on my 05, and i cyl 1,2,4 were within specs. but cyl #3 was off by 14psi which was the max. that was on dry test, but on the wet test, cyl 1,2,4 have gone up a good amount of psi, but cyl 3 only wejnt up 3 psi. does anyone have an 05 to compare results?
Old Mar 19, 2006 | 09:24 AM
RazorLab's Avatar
Last time I checked my 05, I was 185 - 180 - 185 - 186
Leak down test too, came out fine, no leaking.
This was with 18k at the time of the test, 7 open track events, 3 in over 100 degree heat.
