Does the stock wg arm need to be adjusted for high boost?
Ok im about to get tuned by Al for high boost and meth, my car holds boost fine at 22psi will I need to tighten up the stock wastegate arm to be able to hold the high boosts of meth? thanks
A turn or two MIGHT help, but tighten it down too much and you will have issues with it not opening up enough! It would be better to go with an actuator with a higher spring rate.
Keep in mind stock wastegate actuator diaghram isn't really designed to opporate with more than 19 psi, tightening the spring will increase actuation pressure.
A broken WGA will cause unregulated boost.
Mine is still stock and kinda worrys me having it tightened. Darn it, thanks for reminding me I need a WGA upgrade.
Ok, my car gets tunned tomorrow, Im sure Al will and always has done everything in the past to help me out, even on the spot. I guess i should rewrite the question. Has anyone had boost holding issues at say 28psi with the stock actuator in the stock setting? and will adjusting it help. thanks again guys. Also when get to Al tomorrow my motor will be hot from the drive down there, so I would like to fix it before hand. thanks again.
Before I tightened preload, I would taper in first and second up top as if I had a boost leak. tighened act preload and taper mostly gone. (held 20 psi practically to redline in 1st gear).
So yes that baby allows the WG to crack open when exhaust flow is high.
I cant imagine at 28 psi, thats alot. I bet the thing is probably half open while still building.
on a mbc, the "little wg reset hole" on the mbc wg nipple is too small to allow pressure to escape/wg to stay close------>leading to boost tapering.
either drill the "little wg reset hole" out OR tee a adjustable needle valve onto the MBC/WG hose to bleed pressure off to lessen tapering.
Liqquid
50
Jun 22, 2008 05:50 AM
TREVORSEVOVIII
15
Nov 20, 2007 12:23 PM
blackonblackevo
30
Jul 5, 2007 05:18 AM
