Broken bolt in hotside...0....me...1
Old Apr 17, 2006 | 02:39 PM
althemean's Avatar
I am tearing the engine down to rebuild it and I got the manifold/turbo assembly out as one unit. I hosed down all the bolts with lube and let it sit. Damn did that O2 housing and turbo-mani bolts seize up. In the end all I broke was one bolt on the hotside from the mani to the turbo.
It took me 25 drill bits and seven hours to drill it out I even destroyed a snap-on screw extractor (ripped the cutting flutes clean off). In any event....the hole has some messed up threads (the top three) The rest are clean, I ran a tap through it but the metal just isnt there any more.
Do you guys think it will still be alright and the bolt will hold? There is about 3/4 clean threads left.
Old Apr 17, 2006 | 02:53 PM
kimletrim's Avatar
Registered User
Common occurrence actually with these studs on the turbo related parts. Just get it rethreaded and you should be OK.
Old Apr 17, 2006 | 02:56 PM
DCsleeper's Avatar
You will probably be fine...besides what other choice do you have. You will know when you torque it back down to spec.
Next time you have a bolt break off like that...heat the surrounding area up cherry red and then use your stud extractor to get it out. I had that happen on my buddies cobra before. Trust me we tried everything else first, but that was the only way to get the stud out.
Old Apr 17, 2006 | 03:00 PM
althemean's Avatar
Believe me....I did. I put an oxy-act torch on that sucker and turned it red-hot. It still would not budge. I eventually got it out with an 8mm tap and that finally bit the metal and turned it back out through the bottom.
I could not believe how hard that bolt was in there.
I want to get this hotside coated too...thats why I would hate to waste the money on it to find out it leaks from the bolt loosening up. Oh well....I may drill the bolt heads and safety wire them.
