clutch wont disengauge!!!!!!
Old Apr 20, 2006 | 10:24 AM
VRamirez2004's Avatar
I burned out my clutch and put in a new clutchmaster stage 3, I had the stock flywheel resurfaced, I cant get put it in first gear every time I try to the car just starts going forward even though I have the clutch pedal down , they have adjusted the clutch pedal height, I would really apreciate some help thaks in advance!
Old Apr 20, 2006 | 10:42 AM
ACTman's Avatar
Your best bet is to call Clutch Masters at (909)877-6800 and see if they can help diagnose the problem. My thoughts: If you have adjusted it as far as you can without preloading the cylinder and it still doesn't work, the next thing to check is that the release bearing is clicked in all the way which makes it crooked on the pressure plate. If it is crooked it will not only take excess travel to operate, but it will cause the center peices of the pressure plate to fail and fall off. You may also be noticing a vibration through the pedal if this is the problem.
Old Apr 20, 2006 | 10:45 AM
Zeus's Avatar
I've seen this problem on a couple of those clutches (including my own)... ClutchMasters is little to no help as their standard answer is "pull the clutch out and send it in"... Well, they seem to be good about replacing units, but that doesn't help customers with shipping, labor, or even worse their time if they do the work themselves.
Old Apr 20, 2006 | 11:18 AM
SSKILLA's Avatar
i had that same problem.............i had to get rid of it and get a ACT
Old Apr 20, 2006 | 11:21 AM
My friend has an ACT too but his did the same thing, but adjusting the clutch pedal worked for him I dont know why it didnt work for me??
Old Apr 20, 2006 | 11:22 AM
SSKILLA's Avatar
check your slave
Old Apr 20, 2006 | 11:25 AM
EVOIX4me's Avatar
That sucks all that work to find out the **** doesnt work
Old Apr 20, 2006 | 01:46 PM
what should I check for in the slave cylinder?
Old Apr 20, 2006 | 01:48 PM
Warrtalon's Avatar
Did you check the clutch rod yourself, or are you just relying on what those guys tell you? It's a very easy thing to do yourself, so I suggest going to Evomoto.com, reading the how-to write-up, then go check it yourself. If your clutch rod is not almost on its last thread, then you still have room to adjust it. What you're describing is a pretty classic example of the clutch rod not being adjusted out enough. It even happened on my ACT at one point before re-adjusting it.
Old Apr 20, 2006 | 01:51 PM
I watched him do it, he adjusted it so much it fell off but he put it back on of course
TariqEvo
Jul 18, 2017 07:22 AM
Erraticevo666
Apr 12, 2016 06:22 AM
bluevilevo8
11
Sep 7, 2015 06:30 AM
Johnboy1065
Mar 23, 2008 03:48 PM
Fifty
13
Dec 23, 2007 09:12 AM
