tap for water injection?
I recently purchased a water injection kit. My car goes to turbo trix on may 6th and I am puttign cams and ecu tune and I would like to have my water kit installed before then. what is the best place to tap for water injection? before the TB?
Originally Posted by smoothmarine187
I put mine in the bottom of the Upper Intercooler pipe right before the flex fitting that goes to the Throttle Body.
Originally Posted by steinvb12
Just have Turbo Trix tap it for you. That way you know it's right and in the right position. You can install everything else if you want, just don't tap the line.
btw, don't use tap water. use distilled water. the little water jet will clog on tap water. of course you could clean it monthly.
I inject water just after the bov hose in the upper intake pipe. I used to inject down by the intercooler, but someone mentioned possible water injestion during blow off. don't know if it was a real problem but thought I would error on the safe side.
