TME and E IX compressor maps/ flow#'s?
Old Apr 25, 2006 | 07:23 PM
RaNGVR-4's Avatar
Does anyone have any flow numbers or compressor maps for both the TME and E IX turbo's? i found one map for the TME but i cant find anything for the 9. Grazie,
Ryan
Old Apr 25, 2006 | 07:56 PM
Warrtalon's Avatar
Probably would help if you put a question mark at the end of the topic title. I thought you were giving us these numbers, not asking for them (btw, only a mod can do it, so make a request to Blonde).
Old Apr 25, 2006 | 08:45 PM
RaNGVR-4's Avatar
strange. thanks for the head up though
Old Apr 25, 2006 | 10:08 PM
Evo_SpeedKing's Avatar
this is something i too would like to see to help me decide in a future turbo upgrade.
Old Apr 25, 2006 | 10:28 PM
boomtown's Avatar
Given that its a 16G wheel for both I suspect you are going to find a 3/4ths of bugger all difference on a compressor map (despite the revised housing).
Flow figures on the other hand would be interesting.
*Edit* Can you post your TME map so I can compare it to my GSR 16G map to see if there is any difference at all?
Old Apr 26, 2006 | 11:53 AM
RaNGVR-4's Avatar
here it is off of forced performance:
Old Apr 26, 2006 | 11:53 PM
RaNGVR-4's Avatar
bumity bump bump
Old Apr 27, 2006 | 12:45 AM
boomtown's Avatar
Sorry thats not a TME map. The code for the TME turbo is TD05HRA. Thats just a TD05HR which is the standard aluminum compressor wheel found on GSRs.
But I still think that the maps on the compressor side should be very close or identical. So thats probably why FP is using it.
Old Apr 27, 2006 | 11:09 AM
RaNGVR-4's Avatar
yes, it is. almost all evo4-9 turbo's compressor wheels are identical. the only thing about the 9 is it has a different compressor housing, which will change its efficency. the specail thing about the TME is its Titanium+Aluminide shaft and turbine wheel.
i cant believe noone here has any actual flow data on a 9 turbo. how does anyone think its so better hten?
Old Sep 3, 2006 | 11:10 PM
trinydex's Avatar
wrong... the 9 compressor wheel is a different shape.
Old Feb 16, 2007 | 05:11 AM
cij911's Avatar
I too am interested in the 9 compressor / efficiency maps....Any info. ??
Evo Ate
54
Jul 20, 2012 06:25 AM
boomtown
71
Jun 22, 2006 02:33 PM
mercedevo
Jan 8, 2006 11:44 PM
