IX Fuel Pump for my mods
2006 Evo IX
Mods:
Works Cat-back
Works HFC
Helix v2 downpipe
Stock BOV
Cone K&N
MBC (set to safe setting)?
Im going to be getting a custom Dynoflash.
This is my only car and I drive it every day so I looking for a safe tune but I want it to still give decent overall performance.
so do I need to upgrade the IX Fuel Pump?
Mods:
Works Cat-back
Works HFC
Helix v2 downpipe
Stock BOV
Cone K&N
No, I'm not sure why you'd come to that conclusion. If it fails, which would be strange, it would probably take out the engine. That's not the main reason for getting a fuel pump upgrade, though.
Ok then what is the main reason for getting a fuel pump?
Why are people saying it cheap insurance?
Also can you safely ran a Walbro 255 before the flash?
Why does Al recommend it?
I really don't know much about installing a fuel pump (I've looked at the DIY for it) but I do know a friend who did it on his Evo.
It's so that you can supply enough fuel for raised boost without worry. It flows more than the stocker. The reason why we don't say they're required on IXs with basic mods is because it's upgraded over the VIII fuel pump. It's cheap insurance, because it's $85. You can safely run a Walbro without a flash, but it would just make you run more rich than you already are. No reason to do that. He recommends it, because he doesn't like motors to pop. The write-up is on Evomoto.com.
neonglh
Jun 9, 2010 11:39 AM
.MM
33
Sep 21, 2007 12:34 PM
