Rear O2 Sensor removal? Will I be able to run completely without it like this?
So I completely tore out my rear o2 sensor and its completely ruined. And a new one costs 300+, so is it possible to splice in a o2 sim, and the tap the temperature reading from the front o2 sensor into the ECU?
If anyone else has some suggestion it'd be great too thanks
Get a new one from www.oxygensensors.com 92.50 for the with the clip (03) I bought that and had to cut the clip off solder the 05 one on. The cheaper one is like 59.90 and free shipping too. If you run with out a rear O2 it will give you a SES and if your o2 sensor is all damaged a o2 sim most likely will not help.
Dawid5surowiec
Aug 2, 2013 06:31 PM
bnr34rb26dett
Oct 24, 2011 06:40 PM
