walbro pump install question,,??
Old May 29, 2006 | 05:12 PM
Dr. SS's Avatar
i installed the walbro following the instructions of EVO MOTO. i followed them to the t. it went smoothly and took about an hour.
now the car wont start.
trouble shooting suggestions???
Old May 29, 2006 | 05:16 PM
smokedmustang's Avatar
Are the wires on backwards? did you disconnect the battery before you did this? did you reconnect it? Disconnect the negative on the battery, and re-set the ECU. Maybe it detected you disconnected it. car wont turn over? or you have no power?
Old May 29, 2006 | 05:23 PM
EvoRicer's Avatar
I followed those same instructions on my 8 and 9. Nothing wrong after install.
Old May 29, 2006 | 05:36 PM
56Hotrod's Avatar
Could be a bad Walbro...I think there are a good percentage of ones shipped that are faulty. Do you hear it running?
Old May 29, 2006 | 05:39 PM
Dr. SS's Avatar
i took it back out, and hooked it up to my RC truck battery (7.2V) the walbro works fine, i noticed that one of the wires was out of the harness that hooks to the underside of the harness that plugs into the whole pump housing, i replaced that wire, still not starting, will play with it some more.
Old May 29, 2006 | 05:40 PM
Dr. SS's Avatar
and no i dont hear it, is it pretty audible when u turn the ignition on ? (my backseat is still out, so is the cover)
Old May 29, 2006 | 05:42 PM
Dr. SS's Avatar
car turns over fine, there is some electrical issue with the wiring on the pump housing i believe. ill put the stock one in and see what happens.
Old May 29, 2006 | 05:43 PM
4-BNGR's Avatar
bad pump or no fuel
vboy425's Avatar
did you pump the gas pedal while starting the car? if not try that. Also maybe you accidently yank of fthe black ground wire, takethe fuel pump back out and double check.
Old May 29, 2006 | 05:44 PM
kf6ytc's Avatar
You probably hosed the wiring and blew a fuse, hows the fuel pump fuse looking?
Old May 29, 2006 | 05:46 PM
Dr. SS's Avatar
yeah the black ground wire was out of the harness that runs from the top of the pump to the receiving harness on the outside of the pump housing. i put it in, i still dont hear the pump running. i eliminated the pump as a problem, i hooked it up to a battery and it runs.
Old May 29, 2006 | 05:47 PM
Dr. SS's Avatar
Originally Posted by 4-BNGR
bad pump or no fuel
i think its no power.
kf6ytc's Avatar
as long as you have it plugged in proper, and grounded or whatever it needs, i bet you flew the fuse.
Old May 29, 2006 | 10:36 PM
Dr. SS's Avatar
fixed. thanks for the suggestions.
upon taking the pump back out, i noticed one of the wires in the harness had popped loose.
Earthen
10
Oct 26, 2014 05:52 AM
Bladey
Aug 9, 2013 07:58 AM
Ralliartize It
28
Oct 28, 2010 06:19 AM
Fast_Freddie
27
Apr 16, 2010 07:46 PM
xLaNcErEvOx
12
Sep 14, 2005 03:02 PM
