EVO Throttle body question
Ok, on the way back from Maine I started to hear a weird whistle, so trying to hunt it down, I happened to notice on the throttle body, the spot that is labeled "P" has nothing there. Now, did this thing just magically disappear? Or is there supposed to be another nipple and vacumn line like the others? Lastly, if there is, where would it go to? Thanks in advance.
A whole forum full of EVO owners, and not one person can just pop their hood, look at their throttle body real quick, and tell me how many nipples are coming off the top of it?
Originally Posted by Boosted GP
I know that my car has 3 vac lines attatched to the 3 oulets, will look tonight where the "P" line goes to.
Mike
Mike
) for a line on the p position.
Originally Posted by puckadog
spins4, i think you and i have 03 evos... it may be the 05s use all three points, but as i said, on my o3 there isn't even a nipple (i said nipple
) for a line on the p position.Fast forward to today. Being paranoid I just took off the intake to check for shaft play, and none. No in and out, it just has the minimal up and down. Checked all other lines and connections and what not and everything seems fine. Needless to say I'm
big time.
what have you done / touched / modified on the car?
i beleive us evo's dont have a tube/nipple installed into the"P" of the tb.
have you looked @ yur boost lines coming off the turbo to the w/g actuator?
are you still making reasonable boost levels?
10.5 hot side
RNR 3" O2, turbo back
Greddy front mount
Greddy RS bov
Hallman mbc set to 21psi
Dejon intake
K&N
Magnecore wires
Walbro 255
ACT clutch set up
Turbotrix dyno tune / ecu flash
I checked all the vacumn lines going to the bov, boost controller, wg..all seemed good. Now as for boost levels, everything is fine, as a matter of fact (and this is what confuses me) the car pulls harder than ever!
FS[Northeast]: Evo 8/9 oem throttle body W/O Sensors
yellowevo82
10
Mar 17, 2017 06:42 PM
