boost leak please help!
Old Jun 20, 2006 | 08:00 PM
nongtat's Avatar
my car start to have boost leak at 24psi and above.
First I thought is because of the bov or the connection of the hose or pipping.
but I check all the hose and the pipe everything is perfect fits.
change bov couple time and right now it is aps one. still have this issue.
I saw some post before about the hallman mbc bov that you need some mod to hold the big boost. I am trying to search again but cannot find it.
is this possible cause by my mbc?
(when the car boost at 25psi, I can hear ssshhh... and my needle boost gauge moving very fast from 23-25psi, and Then after couple seconds it hold at 25 psi perfectly) So basically it don't drop the boost. it just not perfect boosting
thank you and sorry for my english.
Old Jun 20, 2006 | 08:05 PM
Evil_1's Avatar
How did you know you have a boost leak? Did you do a pressure test with compressed air? Or did you just come to the assumption based on what you hear?
Old Jun 20, 2006 | 08:07 PM
nongtat's Avatar
yes, So can you clear me out?
Old Jun 20, 2006 | 08:11 PM
C6C6CH3vo's Avatar
It holds boost fine but bounces around?
Old Jun 20, 2006 | 08:15 PM
nongtat's Avatar
yes.... sorry I should say that in the first place
but the bounces around is it normal?
Old Jun 20, 2006 | 09:34 PM
AutoEuphoria's Avatar
Probably a tuning issue more than anything.
