The ultimate HKS272/272 Cam Timing????
Old Jun 22, 2006 | 04:25 PM
Wangracing's Avatar
Hi crew,
I have been contemplating and searching cam timing data for a while now and trying to decide which cam timing setup would suit me best. I am after the typical good hard hitting spool up chucky midrange and if I was going to lose anything I guess I would accept sacrificing a little top end as you cant have it all.
Primarily want the car setup for street twisty hills runs and Auto X.
The most commont settings I have seen are the Bushur -3/-3, the Silver Surpher -4/-1 and a claim that HKS user -2/+1. These produce the following results. (Please correct my maths if it is wrong) Which of these do you think will best suit my needs????
I know there is some dyno testing to show the Bushur settings seem to spool earlier than the -4/-1 but lose a little on the top end to these settings. I was wondering if the -2/+1, while having the same LSA, might actually shift the power curve a little to the left? (Ie come on earlier...)
All comments greatly appreicated.
HKS 272/272 Cam Timing
0/0
Intake Cam Centre 110
Exhaust Cam Centre 110
LSA 110
-2/+1
Intake Cam Centre 114
Exhaust Cam Centre 112
LSA 113
-4/-1
Intake Cam Centre 118
Exhaust Cam Centre 108
LSA 113
-3/-3
Intake Cam Centre 116
Exhaust Cam Centre 104
LSA 110
Old Jun 22, 2006 | 05:48 PM
Jeff_Jeske's Avatar
I run -2/-2 it provided me with 1k rpm earlier peak torque than 0/0. I lost about 10WHP up top but picked that much up in mid range. If you are an autocrosser you'll want the -2/-2 settings if you are a drag racer you'll want the -4/-1 settings. If you are cheap you shouldn't even get cam gears because in my opinion they really aren't worth it. All they do is move power around a little. You aren't going to see +30WHP by adding cam gears. If someone shows you a dyno graph like this then they have inconsistant variables.
Old Jun 23, 2006 | 12:52 AM
Wangracing's Avatar
No worries. Already have the cam gears so will use them and try to get whatever benefit they may offer.
Any comments on the -2/+1 setting???
