Factory Knock Sensor
Old Jun 22, 2006 | 04:25 PM
EvilBlueEvo8's Avatar
Anyone know where it is and/or have a picture of it? And what Bosch sensor replaces it?
Old Jun 23, 2006 | 12:01 AM
cpoevo's Avatar
I cant find a picture of one, but it is located between #3 and #4 cylinder under your intake manifold. It looks like a oil pressure sending unit for the old style gages. Hope this helps.
Old Jun 23, 2006 | 04:44 AM
thats awesome. i was just gonna bump this for an answer. do you know if its a pain to replace and whether or not the bosch one needs to be wired in or if it just plugs in?
Old Jun 23, 2006 | 08:14 AM
cpoevo's Avatar
Are you adding another one, or is your factory one bad? If you are adding one for datalogging or the KnockLink it uses a different type of sensor. The factory sensor is a flat response type, the Bosch sensor used for the KnockLink is a resonance type. Let me know why you are doing this. I added another knock sensor for datalogging and I just put it on the head and ran 2 wires. Cost was $75 for the sensor and harness. Just let me know.
Old Jun 23, 2006 | 10:29 AM
i'm adding the knock light. i was going to just use the oem one and turn down the sensitivity on the light really low. i did go outside and check and i can see the factory one. looks really hard to get to. how did you add a new one to the head?
Old Jun 23, 2006 | 04:16 PM
C6C6CH3vo's Avatar
Old Jun 23, 2006 | 04:22 PM
C6C6CH3vo's Avatar
The easiest way to get to it is from underneath (NOT with jacks). You can access most of the engines backside from there.
I think the knocklink uses the factory sensor and turboXS requires a Bosch
Old Jun 24, 2006 | 02:48 AM
so where can i install the bosch? the oem location or another one? and what wiring would be involved?
Seancj
Jul 19, 2015 06:31 AM
Seancj
Jul 14, 2015 02:45 PM
Beemen550
Jan 4, 2015 11:03 AM
4G63_EVO
10
Apr 26, 2014 10:58 PM
Piro Fyre
Jul 31, 2010 12:18 PM
