help installing hallman mbc
Old Jun 24, 2006 | 10:24 AM
03redtype-s's Avatar
HEy guys i just have a quick question. As i was reading this post https://www.evolutionm.net/forums/sh...r+installation what i got from it is that you remove your factory boost lines right? Yes this is the first time ive done this so it might sound stupid. basically waht i will do is take some vaccum line from the wastegate side of the mbc to the wastegate nipple and the turbo side to the turbo nipple right? Any help woudl be greatly appreciated for a first timer!!!
Old Jun 24, 2006 | 10:31 AM
Warrtalon's Avatar
Yes, that is what you do. You couldn't clarify that in the thread you referenced? It is stated clearly and even has a pic...
Old Jun 24, 2006 | 10:35 AM
4-BNGR's Avatar
run it off the manifold...
A) cap the 1) turbo nipple 2) air intake tube nipple and 3) 2 wastegate actuator nipples
B) run a line from the wastegate to the side of the MBC
C) "T" in a line in between the intake manifold & bov and the bottom of the MBC
Old Jun 24, 2006 | 10:43 AM
Warrtalon's Avatar
The BOV method is also clearly stated in that thread - no need to explain it.
Old Jun 24, 2006 | 01:51 PM
with the lines i leave disconnected in the diagram on this page can i just zip tie them up or do i need to disconnect them from the factory boost solonoid and cap those off?https://www.evolutionm.net/forums/sh...&highlight=mbc
Old Jun 24, 2006 | 02:05 PM
dan628's Avatar
Its better to use the turbo nipple as the source, I like doing it better that way than the BOV method which so many people are hooked on...
Old Jun 24, 2006 | 02:36 PM
well i have tried both today and still nothing. boost to 12 psi and nothing more. That is opening it up one full turn. i just got done hooking it up the way that is in the diagram on my second post and still nothing. What could i be doing wrong?
Old Jun 24, 2006 | 07:21 PM
hallman owners please help me out!!!!! or any mbc owner for that matter could it be that i just didnt have the knob turned enought i had it turned a full turn and a half and it still didnt matter!!!!!!!
