REV To 9 Grand
Old Jun 29, 2006 | 04:06 PM
Jean's Avatar
REV To 9 Grand
I heard there is a mod out there that allows you to rev to 9 grand.
I think it involves just head work, does anyone know the name of the company?
Old Jun 29, 2006 | 04:17 PM
Noogles's Avatar
It's called Valvesprings and Ti Retainers.
Unless you have a Big Turbo and Aggressive cams there is no point in reving the motor to 9000 rpm. the stock turbo can't support it.
Supertech, Rev, Crower, Cosworth, Piper, And Revolver all Make springsets that can handle that high RPM
Old Jun 29, 2006 | 04:20 PM
Silk's Avatar
Its called Vtec. If you want to rev that high for cheap go buy a honda. Even if you got your Evo to rev that high you wouldnt be able to shift with the stock transmission.
Old Jun 29, 2006 | 08:34 PM
scherejs's Avatar
Why would you even want to, unless you have a HUGE snail on it?
Old Jun 29, 2006 | 10:06 PM
Derek888's Avatar
what do you mean you wont be able to shift at 9k...it will not go into other gears?
Old Jun 29, 2006 | 10:18 PM
VTECH8TR's Avatar
The mod is called SEARCH....
Old Jun 29, 2006 | 10:21 PM
DCSilvrEvo's Avatar
Old Jun 30, 2006 | 10:27 AM
jmartinez1170's Avatar
1++
We have gone over this so many time.
Old Jun 30, 2006 | 10:32 AM
Silk's Avatar
Most evo trannys and stock clutches dont even like shifting at anything over 7k, to get your car to shift and 9k your tranny would need to take a visit to T.R.E. or sheppard as well as a nice twin disc clutch from Tilton or Exedy.
Old Jun 30, 2006 | 10:51 AM
Evo9"Miss Rose"'s Avatar
the farthest you can take it...with a flash would Recommend 7800 at most... soo your best goal too reach 9k-10k would be a HONDA!! ive been in a car that hit 10.8K now thats fun untill the car blew and checked it out and the valves just gave up.. feel sorry for them HONDA'S Owners think there unstoppable with there V-tec LoL..oh well....sooo no hitting 9k in EVO's budddy
Old Jun 30, 2006 | 10:59 AM
edwin's Avatar
Heres one of the best I know : http://www.jacksonautomachine.com/
If you want to know anything more about them, you should call them up!
They know SHlT!!
Old Jun 30, 2006 | 11:04 AM
Vishnu_Evo8's Avatar
You will need a new block as well to do it all day. The slowboy racing 2.1L revs to 10.5 k i believe.
http://www.slowboyracing.com/shop.ph...e94a36d62c0763.
This type of motor is only required for guys with 42rs and such.
Old Jun 30, 2006 | 11:13 AM
scorke's Avatar
A cosworth head and a reflash will do the trick.
Scorke
Old Jun 30, 2006 | 11:15 AM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
i was reving my stock motor (besides cams and headbolts ) to 8600 rpms ....only reason was i had a big turbo but even more so was the fact that i needed it to run through the traps at 129mph....
Old Jun 30, 2006 | 11:18 AM
Ted B's Avatar
It doesn't matter one iota who built the motor or what head it has. Without a turbo that extends the power band high enough to warrant a 9k rpm shift point, there is not one good reason to attempt it . . . unless one is just dumb enough to enjoy beating up the motor and going SLOW.
