100 octane IX boost setting
Old Jul 9, 2006 | 06:50 PM
5k6's Avatar
5k6
What is a good setting for 100 octane racing fuel for my IX:
3" Works TBE
HPF Full Intake
Hallman MBC
Custom Dynoflash
I got my MBC set to 22psi on 93
and I normally set my boost to 26 on 100 octane.
is 26 too low?
Old Jul 11, 2006 | 07:44 PM
triple6's Avatar
bump
Old Jul 11, 2006 | 07:45 PM
SiCKlEyWiKeD's Avatar
boost whatever the hell you want on 100 but where you have it is fine.
Old Jul 11, 2006 | 07:48 PM
elhalisf's Avatar
26 is a bit on the agressive side, but ok.
Old Jul 11, 2006 | 07:52 PM
^ 26 is fine just has to make sure the car dosen't pull timing.
Old Jul 11, 2006 | 08:10 PM
SmokinJoe's Avatar
I wouldnt go too much higher on the stock turbo. It pretty much peters out anyway. Esp w/ stock LICP and manifold.
Here is my EVO 9 - 26psi - EcuTek - 100oct
Old Jul 11, 2006 | 08:23 PM
Sharkbite2000's Avatar
Very nice numbers.
Old Jul 11, 2006 | 10:03 PM
5k6's Avatar
5k6
well since it only tuned for 93 I think 26 is ok on 100, I don't run it on 100 that often anyway because its like $5.00 a gallon. I keep it at 22 on 93. The only thing is I don't have ARP head studs?
Old Jul 11, 2006 | 10:06 PM
5k6's Avatar
5k6
Thats what Al told me since im tuned for 93
Old Jul 11, 2006 | 10:10 PM
Warrtalon's Avatar
Doesn't matter what you're tuned for, you can do whatever boost you want on 100oct. If you go over 26psi, it will make more torque, but it won't make much difference in peak WHP, since the turbo can't sustain those high boost levels for long.
Old Jul 11, 2006 | 10:12 PM
WannaRace's Avatar
On second thought, you might not want to go that high on stock head studs.
Old Jul 11, 2006 | 10:14 PM
Warrtalon's Avatar
It's not a problem on the stock head bolts either.
Old Jul 11, 2006 | 10:27 PM
her0's Avatar
Yea? If your tuned for say 91 octane then crank the boost to say 23psi when using 100 octane you will not run lean? Seems like a/f will need to be re-tuned, no?
Old Jul 12, 2006 | 04:08 AM
SmokinJoe's Avatar
100oct just keeps the cyclinder cooler - that's all.
If you were tuning for 100oct, and you ran 93 at 22psi - that's when you could have problems. B/c of aggressive timing, fuel mix, etc.
Old Jul 13, 2006 | 07:49 PM
smilely's Avatar
how much
30 psi all day, OK. No problems.
