Question about Tein Flex
I have Tein Flex currently installed, so here's my question..
I don't like how squishy it currently feels, if I was to increase the spring rates by adjusting it on the coil over, would that make the ride stiffer? I need there to be less body travel.
I know that you can adjust the height by moving the bottom collar and adjust up or down on the body of the coilover, and the spring compression can be changed by loosening the middle collar and then compress/or soften the spring rate by adjusting it either up or down.
Does that make any sense? Or should I buy different coilovers? I currently have the dampening adjust to the hardest setting.
caelin~
caelin~
