Only 17lbs of Boost?
Originally Posted by hondafan
yes, you'll still have some taper using the stock turbo at higher than stock boost levels but not as drastic.
You didn't think the stock boost tapered a lot? Wow...
Stock boost:
03/04 - 19.5psi@3500rpm, 16psi@6500rpm
05/06 - 20.3psi@3500rpm, 17psi@6500rpm
That's the main thing everyone complains about and attempts to remove right away. That's why we were terribly confused as to how you have a stroker but no boost control. It's like having a GT42r turbo on stock exhaust.
Stock boost:
So what he left me with is a built longblock with 680cc Injectors, Walbro 255lph pump, ACT Street Disk, Tubular O2, Hawk HP+ pads and Slotted Rotors on all 4.
Originally Posted by mrbkkt1
He bought the car used, maybe he has it but doesn't know it. Show up a few pics of your engine bay and maybe we can help you more.
...and the gauge doesn't rest at 0 when the car is off? You need a properly calibrated gauge that reads 0 when it's off...
EvoDan2004
1959
Jun 4, 2025 12:32 PM
