Tuning and break-in period.. what to do?
Old Aug 12, 2006 | 02:13 AM
Bdub25's Avatar
Ok, so i'm going to be installing my AMS 35r kit here soon, and i'm wondering what to do. I will be installing the following:
Fuel pump
Headstuds
AMS 35r kit
1k injectors
AMS FMIC
Alky kit
and i already have the other supporting mods (Cams, cam gears, TB exhaust, EBC, gauges, etc.)
I dont have any engine management besides a basic flash that i had for mods before the big mods i am doing. (cams, intake, tb, cam gears, manifold, outlet). What i planned on doing was going to ams to have a full custom flash on the dyno, but i'm a little confused on what to do.
Should i run my car untuned w/stock injectors, no alky and low boost to break the turbo in before i get my custom flash? Should i just have my car trailored up to AMS with 0 miles on the turbo and new mods and get the full custom flash? Should i just put everything on and run it (besides alky)?
I've heard many different sides to this and nothing has been really clear about this. So i'm making a post to get some opinions.
Old Aug 12, 2006 | 07:25 AM
nrcooled's Avatar
If you have proper monitoring setup just set the wastegate the base psi and take it easy you should be fine. Don't boost (which shouldn't be that hard with a 35R) and keep an eye on your WBo2 to ensure that you aren't running lean or overly rich. Install the injectors there (only takes about 20mins) so you don't have to worry about drivability with the 1000cc injectors.
What you really have to worry about is open loop tuning and running at or below 30% throttle and low boost will keep you out of open loop.
Old Aug 12, 2006 | 07:40 AM
Ang Wen Yan's Avatar
Talking
No break in require on turbo change
Old Aug 12, 2006 | 09:43 AM
Bdub25's Avatar
Sounds good. Thanks guys
Old Aug 12, 2006 | 11:45 AM
pengulns2001's Avatar
turbos dont have parts that need to be broken in like a new engine does so you can go all out right off the bat, it wont make any difference
Old Jul 18, 2007 | 03:04 PM
_EVOlved_'s Avatar
I am also curious about the turbo break-in time. Anyone else chime in?
scheides
15
Jul 25, 2008 06:39 AM
tuner
27
Dec 29, 2006 12:52 PM
Nvr2old32
81
Mar 9, 2006 08:47 PM
Warrtalon
72
Jan 24, 2006 04:50 AM
Nvalenti20
AEM EMS
Aug 31, 2005 11:17 PM
