Adjusting clutch. It adjusts PEDAL height ONLY?
Originally Posted by smokedmustang
Your welcome!! Nice avatar!!
Originally Posted by EvoRSvIII
clockwise on the floor looking up or clockwise looking down at the pedal???
Originally Posted by Turbojunkie
smoked, i have a exedy twin also. ive got about 4 threads showing before the end of the shaft under the u bracket. i may have mine a tad bit high but it got rid of most all the notchy feeling. it engages about 1-1/2" from the top when i puch in the clutch.
Engagement means clutch in?
My clutch is a bit slow...feels like I need to slip it a bit before I can go. How do I adjust to get to the point where I just release clutch and go instead of slipping it a bit? Thanks.
Does the clutch adjustment adjust the "height" of the clutch pedal only? OR does it effect when the clutch engages? I assume this will prolong the life of the clutch somehow? ie makes sure there is no incedental rubbing of the clutch material if engagement is 1" off the floor, as opposed to 3" off the floor?
I have a stock one in my driveway (Friends), and his clutch engages 3" off the floor, or "close to the top", and my Twin Plate engages 1" or so off the floor, and it appears this measurement is different at different times of "Heat" in the motor. Any input, or are you gonna send me packing on a "search" mission?
Originally Posted by Evillusion
Mine does the EXACT same thing. Noize and RallyRedEvo drove my car and hated the clutch engagement. I'm almost used to it, however I'd like it to be more like 2"-3" off the floor. I tried to adjsut it, but I guess Im stupid because I couldn't figure out how to do it.
Hey smokedmustang, ever check how many threads you have on the inner side of the u-bracket?
Curious, because I adjusted my car's clutch (Exedy twin-disc HD) and I still get locked out of 3rd gear at times.
) I am off tomorrow, so I can go check it out, and let you know tomorrow. I haven't gotten locked out of any gear using an exedy. I will check and report back to you in the AM.
Thanks.
BTW.......Why's the car in the shop?
My clutch engages very far...like 3 inches+ but even then sometimes If I try to put it into first with my foot to the floor I can feel my car move when I put into gear. Its not lurching but enough that I notice it. Should I adjust the clutch up some more? I'm assuming that it wouldn't matter as the engagement shouldn't take 3 inches so... *shrug*
