bearings
Old Aug 26, 2006 | 11:49 AM
Evoisdream's Avatar
bearings
hey guys im building the motor somewhat and wondering what most people have been using for bearings. im only finding them in the dsm sections of some of the site and seeing clevite etc.
wondering what some of u with built motors are running and where u picked them up at. let me know thanks
Main&rod plz
Evoisdream
Old Aug 26, 2006 | 04:50 PM
Evoisdream's Avatar
need some help on these links it shows 2 part numbers im assuming 6 bolt is one and 7 bolt is the other now which one is which anyone have any ideas?
http://www.slowboyracing.com/more.ph...=14-720,21-719
http://www.slowboyracing.com/more.ph...=14-711,21-701
need to know the part number for the 7 bolt so i can get them orderd. Thanks ahead of time
Old Aug 27, 2006 | 02:33 AM
NDgsx's Avatar
I've been happy with ACL bearings, their mains are all full grooved.
7 bolt engines come with different bearing thickness, I'm not sure if aftermarket bearings are available in varying thicknesses.
Old Aug 27, 2006 | 08:05 AM
Evoisdream's Avatar
from thier site it looks like its different thickness but i do need 7 correct?
Old Aug 27, 2006 | 10:07 AM
aps's Avatar
aps
If you want strong bearings then you should go Power Enterprise bearings.Price is high but ıt is worth the money.
Old Aug 27, 2006 | 12:40 PM
Knightracer's Avatar
Buschur racing has good race bearings for sale. Its the same as what they use in their race car. They seem to take 10,000 rpms well enough, should work for anyone else.
Old Aug 27, 2006 | 12:52 PM
NDgsx's Avatar
Yes you need 7 bearings, the journals are narrower on the later engines. What rods are you running?
Old Aug 27, 2006 | 12:54 PM
Evoisdream's Avatar
i got an eagle rod ross piston setup
probly gonna run the clevite bearings as i can get a great deal just need to know what ones to get.
also got all arp hardware
Old Aug 27, 2006 | 01:43 PM
NDgsx's Avatar
Check with whoever you bought the rods from, but if I remember correctly Eagle uses 6 bolt rod bearings, and you have to check clearance to the filet radius on the rod journals. Sorry I can't help you out more on this, I've built more 4G63s than I can even remember, but they're all 6 bolts for DSMs.
ACLs are inexpensive as well. I've run clevites in the past and they work ok also.
Old Aug 27, 2006 | 02:06 PM
Evoisdream's Avatar
hrmm yeah i figured it was 7 bolt...... im confused now hahahah clevite seem like they will b good i dont plan on making 800 hp or anything lol
