Shifter/Slave cylinder mod **WOW**
Old Sep 1, 2006 | 07:29 AM
Turbo Kyle's Avatar
Last week I installed the Authority Shifter with the Speed sorce bushings. Last nigh I removed the clutch line restrictor. We also added the Stainless clutch release rod. Then adjusted the clutch peadal. The car shifts way better, night and day. Also when launching the clutch does not slip as bad. The shifts are nice and shooth. I would reccomend this mod to anyone . Going to the track tonight to see what she can do. The only power mod is a K&N Drop in filter. Car has 1450 miles
Old Sep 1, 2006 | 07:34 AM
eve-slow's Avatar
Cool, keep up posted on your times.
Old Sep 1, 2006 | 07:36 AM
ExViTermini's Avatar
must be nice to be able to go to track...raining like hell here.
And yes removing the restrictor and adding stainless line helps dramatically, I'll second that
Old Sep 1, 2006 | 07:47 AM
Turbo Kyle's Avatar
I will post them tonight or in the morning. We are going to Midnight Madness
Old Sep 1, 2006 | 09:16 AM
BURNALL_4's Avatar
i did that on my 05', probally one of the best things i did......it helps so much
Old Sep 1, 2006 | 09:24 AM
marksae's Avatar
The problem w/ doing so many mods at the same time is that you don't know which mod was the biggest contributor to the improvement. I've done all those mods one at a time except a short shifter and I found removing the restrictor to make the biggest difference.
Old Sep 1, 2006 | 09:44 AM
Turbo Kyle's Avatar
I did the shifter a week ago, helped on shifting. I did the restrictor last night along with a stainless ROD, no the line. The restrictor made the biggest diffrence. The car shifts way smoother, it seems like the clutch disengages fully for better shifts.
Old Sep 1, 2006 | 09:56 AM
justchil's Avatar
Ditto on the restrictor making a big difference. Am I alone in seeing no need for a short shifter?
Old Sep 1, 2006 | 10:02 AM
Soon2BEVO's Avatar
How do you eliminate the restrictor? I had my ACT clutch with SS line installed by Turbotrix... is the restrictor in there still?
Old Sep 1, 2006 | 10:16 AM
Turbo Kyle's Avatar
I would say you dont really need it. I would at lease do the bushings under hood and shifter base. However shorter is faster. I like my short throw.
Soon2BEVO,
It may be in thier. Call TT and ask them if the did.
Old Sep 1, 2006 | 11:31 AM
Soon2BEVO's Avatar
Will do
AWD Motorsports
AWD Motorsports - Florida
293
Jun 14, 2016 10:25 AM
Bignel00
Mar 27, 2015 10:48 AM
IntegxX
12
May 2, 2012 07:21 AM
LakerRaider
34
Jul 16, 2011 08:05 PM
RalliArtEvoVIII
19
Jun 15, 2005 06:32 AM
